Directional signal flash rate problem
Old Aug 2, 2007 | 05:24 AM
Digiti123's Avatar
Default Directional signal flash rate problem
My directional blinker signal is excessively fast when making right turns. The left signal is working normally. I did notice that one of the two bulbs in the front right was burned out, so I had it replaced with an 1157 bulb. Unfortunately the problem perists even with the new bulb. Any help will be appreciated. Thanks.
Old Aug 2, 2007 | 06:20 AM
Andryzzle's Avatar
Default Re: Directional signal flash rate problem (Digiti123)
check and see if you have any other lights out
robin-m
Honda CR-V & Element
Jun 19, 2014 06:25 PM
EL Vap133
Apr 16, 2008 09:06 AM
jasony0630
Feb 22, 2008 03:43 PM
Weapon_R
Nov 12, 2004 07:29 PM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
