Halo Projector Bulb Size
Old Aug 2, 2007 | 01:05 AM
confuseid's Avatar
Default Halo Projector Bulb Size
http://cgi.ebay.com/ebaymotors...&rd=1
What bulb size do you guys think this takes?
I regret buying it, If I only chipped in like $40 more I could've had some TYC's, but I didn't know about it at the time. So i'm stuck with generic Halos.
I have them but I don't know what bulb size to use.
I also want to use HIDs but I don't know if I can use it without burning the headlight plastic case.
I really have no idea what an HID conversion kit is for, I have 9500/9600 HID lights on my stock Accord headlights.
Can't install new headlights without bulbs!
Old Aug 2, 2007 | 05:06 AM
00Accord4cyl's Avatar
i forgot which ones they use..couldn't u just open it up and look at what the bulb says??
but yeah light output sucks on them..i couldn't stand mine
Are you planning on putting ur stock back on and then getting ur hids in those?? they use 9006/9005 i believe..halos mights be H1 bulbs
Old Aug 2, 2007 | 07:41 PM
confuseid's Avatar
Default Re: (00Accord4cyl)
I have the headlights, and no, they don't say what size fits on them.
Is light output on Halos bad? I always thought because it was a projector it would be better.
I already have HIDs in my stock headlights, but I'm going to replace the stock headlights once I get bulbs for my new Halo Headlights.
I just need to figure out what size bulb fits in that. The seller won't tell me. Useless ebay.
Old Aug 3, 2007 | 10:50 AM
yeah the output is pretty bad..it is just a cheap projector, and the bulbs aren't that great..so your hids in stock housing are probably going to be way better than the halos..i am pretty sure they are H1..but i can try and find out..
Old Aug 3, 2007 | 11:56 AM
bseriescrxsi's Avatar
Default Re: Halo Projector Bulb Size (confuseid)
you cannot put HIDs in projectors you will burn the housing out the HID bulbs are too long you need a special projector housing and certain HID bulbs to go with them..but you do need a certain kind of projector headlight not any housing will work
nickoz21
Mar 14, 2007 01:37 PM
KMk51188
Dec 29, 2006 01:21 PM
. a d a m
Sep 25, 2006 10:35 AM
Integra_Boi
Feb 3, 2003 06:43 PM
ih8danoles
Dec 8, 2002 03:10 PM
