Firewall mounted OBD0 MAP to ITR TB mounted MAP wiring change?
Old Aug 1, 2007 | 07:57 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Firewall mounted OBD0 MAP to ITR TB mounted MAP wiring change?
DA with ITR TB, when I extended wires and tried to plug directly into the TB mounted MAP the car ran like hell. Is there some wiring I need to be doing? I have read a long time ago that there are two wires that need to be switched, but I haven't been able to find the thred on here or G2IC.
HELP ME
Thanks,
Chris
Old Aug 2, 2007 | 05:38 AM
Default Re: Firewall mounted OBD0 MAP to ITR TB mounted MAP wiring change? (DAantagonist)
anyone?
Old Aug 2, 2007 | 09:36 AM
I guess no one has done this? I'm wondering if I have a bad MAP? I'll wait for the west coast to wake up.
Old Aug 2, 2007 | 09:42 AM
deftonerider's Avatar
i just left the map on the throttle body unplugged and used the firewall mounted map sensor
i don't know why it doesn't work i wanted to do want you did but was lazy
Old Aug 2, 2007 | 01:55 PM
Default Re: (deftonerider)
LOL. Me too so far, I swear it has to be wired differently, and I've been searching all damn day.
help anyone? Would REALLY like to get this done. I will continue to search.
Old Aug 13, 2007 | 07:15 AM
anyone?
Old Aug 13, 2007 | 08:22 AM
sierrahiker8's Avatar
Deftonerider, which throttle body are you using? and does it throw any cel? Thanks
Old Aug 13, 2007 | 09:48 PM
i have a skunk2 tb but used to have a b20b with an b18b int mani and tb
never threw a code
Old Sep 26, 2007 | 06:22 AM
I have yet to find the info that I needed for that pin switch. It IS possible that MAP is bad. I will try and figure out how to test it...
jphil101
Apr 2, 2010 11:36 AM
braindamaged1972
Feb 1, 2007 07:12 AM
Pooper
Oct 16, 2006 09:19 PM
B18C-RnVA
Aug 18, 2002 03:01 PM
