HAUNTING CEL??
Hey guys listen up today as i was driving after i dropped by a store i drove about 3 blocks and then TUN,TUN,TUN CEL!!!
Funny **** is i shut my engine off and it didnt turn back on. Should i worry? Has this happen to any of you guys? THANX for any input guys
anything happen before any clicks or knocks? motor and car would be great also. and did you check the cel through the ecu? that would help a ton
edit: here's how to check a cel yourself
https://honda-tech.com/zerothread/1901557
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">anything happen before any clicks or knocks? motor and car would be great also. and did you check the cel through the ecu? that would help a ton</TD></TR></TABLE> Well ididnt check the ecu CEL because when it turned of engine to go to other store and came back to drive car for about 20min no CEL came on i mean can i still check ecu if light is not on?
tegedrex
Sep 27, 2003 03:40 PM
