Lowering Negative Camber Can Be Corrected By A Camber Kit? Please Help. Thanks
Old Aug 1, 2007 | 07:16 PM
Mike1995HondaPrelude's Avatar
Default Lowering Negative Camber Can Be Corrected By A Camber Kit? Please Help. Thanks
I bought a 1995 Prelude Vtec that has been lowered. I took the car to a mechanic (kinda speaks English) and he said I needed to replace the whole suspension, coils, and struts to stock. He showed me the tire wear due to negative camber. However, I read about a Camber kits. Can that fix my tire wear problem? Will it fit onto my stock suspension system?
I really appreciate your help. Thanks.
Old Aug 1, 2007 | 07:23 PM
M2B4's Avatar
Default Re: Lowering Negative Camber Can Be Corrected By A Camber Kit? Please Help. Thanks (Mike1995HondaPr
why do you havta change the whole suspension back to stock b/c your tires wear uneven? sounds dumb and yes a camber kit will correct your issues
Old Aug 1, 2007 | 07:24 PM
m00nr0ck Si's Avatar
SPC makes sliding ball joints for the front and rear control arms and they will correct camber from -4 degrees to +4 degrees...only drawback to these is they tend to hit the shock towers if you are lowered too much or if you hit an extreme hole. there are other types such as the ingals kit which replaces the pivot bolts at the rear of the control arm (2 per control arm) and they will do basically the same thing w/o hitting the towers....
All of these can be bought at http://www.nopi.com or http://www.prostreetonline.com and many other web stores...go to the sponsor classifieds here on honda-tech and browse around for a good deal
Old Aug 1, 2007 | 08:08 PM
thanks a lot!!!!
i went to prostreetonline. i didn't see any camber kits for the prelude specifically. However, the 95 del sol has the same double wishbone suspension. Should it fit?
I would really appreciate it if you could send me the link to one that would fit. THANKS A LOT.
Old Aug 1, 2007 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike1995HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot!!!!
I would really appreciate it if you could send me the link to one that would fit. THANKS A LOT.</TD></TR></TABLE>
http://www.nopionline.com/nopi...elude
Old Aug 1, 2007 | 08:17 PM
thanks a lot!!!!
Old Aug 1, 2007 | 08:31 PM
I think I might go with one of these... http://www.performance-curve.c...D=476
Should that fix the problem or will more work be needed. How much should labor be? Thanks for the help
Old Aug 1, 2007 | 08:54 PM
Old Aug 1, 2007 | 09:06 PM
Old Aug 1, 2007 | 09:12 PM
Old Aug 2, 2007 | 09:01 AM
yeah those are the same thing that I posted the link to , only at a better price...
They are pretty easy to install...
-pull off upper control arms
-find 2 blocks of wood to place under the control arm
-get a big *** hammer (5lb.) and hit the ball joint on the threaded end until it pops out.
-install new sliding ball joints and go get an alignment ASAP
Old Aug 2, 2007 | 11:47 AM
THANKS FOR THE HELP!!!
U said ingalls might be a better buy(lack of hitting). What do you think of these? THANKS
Old Aug 2, 2007 | 11:55 AM
red_hondas's Avatar
do not buy the upper ball joint replacement! ive seen alot of holes in strut towers because of them...and they tend to slip. the kit that replaces the pivots is the **** man. get your hands on that one. probably would run .5 to 1 hour per side at a shop. plus the alignment
Old Aug 2, 2007 | 05:32 PM
Default Re: (red_hondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_hondas &raquo;</TD></TR><TR><TD CLASS="quote">do not buy the upper ball joint replacement! ive seen alot of holes in strut towers because of them...and they tend to slip. the kit that replaces the pivots is the **** man. get your hands on that one. probably would run .5 to 1 hour per side at a shop. plus the alignment</TD></TR></TABLE>
I had the SPC ball joints on my Ej2 for 3 years and never had one slide and I drive on some pretty shady roads...not saying it could'nt happen but it would be unlikely if the nut was secured to the suggested torque spec in the instructions.
Old Aug 2, 2007 | 06:43 PM
Default Re: (m00nr0ck Si)
What happens when it slides. And what kit replaces the pivots? thanks
Old Aug 2, 2007 | 06:45 PM
Default Re: (Mike1995HondaPrelude)
how about these?
http://cgi.ebay.com/ebaymotors...&rd=1
Old Aug 2, 2007 | 06:47 PM
if they slide it would take it out of alignment...if they slide inward it would create negative camber and if they slide outward it would create positive camber...
and the ingals kit would be the one that replaces the pivots on the upper control arms...that nopi link I posted has them at the bottom of the page.
Old Aug 2, 2007 | 06:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike1995HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">how about these?
http://cgi.ebay.com/ebaymotors...&rd=1</TD></TR></TABLE>
Those will work ,but remember that these are known to hit the shock towers and wear holes in the metal...
I would personally go with the pivot bolt style , but I think we are all waiting on the ingals upper control arms to become available...they are in development right now as far as I know...these would be simular to the skunk2 control arms for civics...
Old Aug 2, 2007 | 06:54 PM
Thank you soo much. You have been such a help.
I have one stupid question. Since I have an oil leak form an unknown area, the mechanic asked me to spray down the engine with pressurized water so he would get a better look at wear the oil is coming from. I did that, then ran it. Engine light came on. Is spraying the engine then running it bad for the engine(I think I remeber my brother in law telling me never to do that). Mechanic said the light should turn off after a couple miles.
Old Aug 2, 2007 | 06:56 PM
Could you show me the pivot bolt style (link). Or is that the one u sent me, on the bottom of the link's page? Thanks
Old Aug 2, 2007 | 07:01 PM
Those apparently only work on rear
The mechanic also said I would need something that would correct for something around 2.8.
Modified by Mike1995HondaPrelude at 8:18 PM 8/2/2007
Old Aug 2, 2007 | 08:15 PM
Damn, I don't want to break anything (damage towers). I am on a tight budget. Would raising the car, which i don't really want to do, return it to normal camber? I could use one of these
http://www.cardomain.com/shopl...0Kits
Old Aug 2, 2007 | 08:21 PM
M2B4's Avatar
yes raising the car will reduce camber.
Old Aug 2, 2007 | 08:46 PM
Default Re: (M2B4)
So one of those coilovers should do the trick? thanks
Old Aug 13, 2007 | 04:25 PM
red_hondas's Avatar
sometimes water will accidently get in the sensor harness connections and can temporarily set a code. seen it a few times. you have to be careful to spray around sensors and connectors, never spray directly on them. they all have seals in them, but they are only resistant, not water proof. i sprayed a yota p/u once for a power steering leak, and when i got done, the cruise light was flashing like a drunk bitch @ marti gras. couple hours later, all was well.
