Help... transmission/axles ...does this look right.
Old Aug 1, 2007 | 06:57 PM
d16rice's Avatar
Default Help... transmission/axles ...does this look right.
Are the axles supposed to go in deeper?
Driver side….
Passenger side…
I took them out a while ago, and just got to putting them in this evening.
They don’t seam to go in as deep as I though they would.
Is that gap normal?
Does anyone have any pictures of what it’s supposed to look like?
P.S.
This is on a D16Y8
Old Aug 1, 2007 | 07:10 PM
smileycvc's Avatar
Default Re: Help... transmission/axles ...does this look right. (d16rice)
They need to go deeper
Old Aug 1, 2007 | 07:44 PM
2mansi's Avatar
The axle in the picture is not all the way in. When you are putting them in you will need to push a bit untill you feel the axle pop in. There is a bit of a gap but it is not very noticeable when then axle is all the way in.
Old Aug 1, 2007 | 07:45 PM
minime-civic's Avatar
* B A N N E D *
Default Re: (2mansi)
pull that bitch out a lil bit, and ram it in and out until it clicks in there. trust me,
Old Aug 1, 2007 | 07:46 PM
VRD^sam's Avatar
Default Re: (minime-civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minime-civic &raquo;</TD></TR><TR><TD CLASS="quote">pull that bitch out a lil bit, and ram it in and out until it clicks in there. trust me, </TD></TR></TABLE>
thats what i do
Old Aug 2, 2007 | 04:19 AM
d16rice's Avatar
Default Re: (VRD^sam)
I'll try, I'm just afraid of breaking the wrist pins.
Old Aug 2, 2007 | 06:00 AM
instrument's Avatar
breaking a wrist pin
i'm surprised that's never come up with my sledge hammer approach.
Old Aug 2, 2007 | 06:54 AM
EX-T's Avatar
Default Re: (d16rice)
What are you talking about, wrist pin? You're not working with pistons, you're working with axles! You're probably talking about the snap rings...you have to put some *** behind those axles to get them in!
Old Aug 2, 2007 | 03:52 PM
d16rice's Avatar
Default Re: (EX-T)
no luck yet, but I'm still trying.
Old Aug 2, 2007 | 04:01 PM
HeikDiesel's Avatar
When I do my axles I always undo the upper ball join and them I put the axle in the hub and use the knuckle to "hammer" the axle in
Old Aug 2, 2007 | 04:05 PM
cartune network's Avatar
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">When I do my axles I always undo the upper ball join and them I put the axle in the hub and use the knuckle to "hammer" the axle in</TD></TR></TABLE>
ii do that too but i use a rubber mallet to beat the sob's in. ull hear the click. if u cant get um in ur not trying hard enough. lol
Old Aug 2, 2007 | 04:06 PM
DFW's Avatar
DFW
Push it in as hard as you with your hands, if not try putting the hub back through then force it in with the hub. Worked for me.
Old Aug 2, 2007 | 05:00 PM
d16rice's Avatar
Default Re: (DFW)
I finally got it in.
practiced a couple of times on my spare transmission with a spare axle, and once I got the hand of it, I managed to pop them in my car with very little effort.
Thanks everyone
Old Aug 2, 2007 | 05:04 PM
Ramma's Avatar
Put the axle nut on the hub end and hold the axle straight. Then use a hammer to hit the axle nut and it should go right in.
Old Aug 2, 2007 | 05:23 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (Ramma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ramma &raquo;</TD></TR><TR><TD CLASS="quote">Put the axle nut on the hub end and hold the axle straight. Then use a hammer to hit the axle nut and it should go right in.</TD></TR></TABLE>
put a block of wood before you hammer and metal to metal contact. and give this a try. cause they are not in all the way like they are supposed to
good luck.
Old Aug 2, 2007 | 06:59 PM
thehatchninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">I'll try, I'm just afraid of breaking the wrist pins.</TD></TR></TABLE>
hahahahahahahahahahahahahaha
nonvteclude
Aug 7, 2006 08:45 PM
b18bfreak
Aug 2, 2004 10:05 AM
Revolution2zz
May 13, 2004 08:45 PM
xhatchracerx
Oct 23, 2003 01:05 PM
Hatchy-Ownzjo0
May 10, 2002 04:48 AM
