da big brake, lca's, uca's and mc
Old Aug 1, 2007 | 04:42 PM
96pgtmtx's Avatar
Default da big brake, lca's, uca's and mc
91 si hatch. . . .i'm going to upgrade to da big brakes do i need to use the lca's at all
what are the physical differences in the lca's between the ef and da
i'm not planning to use the uppers BUT, if i dump my car should i just swap it out or just buy a camber kit anyways. . . .
is my master cylinder a 15/16 or 13/16 i'm guessing it's 15/16th's because it's an si. . . .
there was something else i wanted to ask but forgot. . .
Old Aug 1, 2007 | 04:47 PM
CRX Toad's Avatar
Default Re: da big brake, lca's, uca's and mc (96pgtmtx)
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread/1508680
This has been covered a few million times.
Old Aug 1, 2007 | 05:00 PM
96pgtmtx's Avatar
Default Re: da big brake, lca's, uca's and mc (CRX Toad)
really all i want to know about is the lca's i didn't see anything on it. . . .
and as for the first one the bitching sucks to read thru, it should be cleaned
Old Aug 2, 2007 | 06:28 AM
mahatma's Avatar
only swap the knuckles.
they'll actually give you a little positive camber (will help some if your car is dumped).
and i'm pretty sure your MC is 13/16. you can bolt the 90-91 Civic EX MC right up, it's the 15/16 one
Old Aug 3, 2007 | 03:00 AM
96pgtmtx's Avatar
Default Re: da big brake, lca's, uca's and mc (mahatma)
yea i figured on swappin the knuckles, brakes and that's about it so far. . . .not sure about the mc yet because i didn't really search . . . .and i figured my search wouldn't pull back alot
(since i'm not real search savvy)
anyways does anyone know for sure on the 15/16 or 13/16ths thing?
Mar 25, 2012 06:59 AM
whole9
10
Mar 30, 2007 10:00 PM
oldskoolaccord
Mar 29, 2007 03:36 AM
CRX-SIR
36
Jun 4, 2005 09:32 AM
Chris
13
Dec 8, 2002 07:55 PM
