Ls/vtec part out. Mounts, gsr tranny, header, ecu, ect
Parting out my motor swap guys, setup consitis off:
Ls/vtec complete longblock:
11.6cp
B18a block
Pr3 pistons + new rings
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
acl main, rod, and thrust bearings
Bored .20 over + fresh hone
Shot peened rods
micropolish crank
balanced bottom end
JG built B16 head
JG port and polish
3 Angle valve job
supertech valves,springs,retainers
comitec head gasket
stock b16 cams
skunk2 adj cam gears
spoon style calve cover
ITR intake manifold/b16 TB
The longblock will come with the following:
injectors
all sensors(iat, iacv, map, tps, ect ect)
Distributor
fuel rail/fpr(stock)
ngk sprak plugs + wires
Alternator
flywheel
6 puck TCS clutch and pressure plate
$2300
I will also have for sale the following:
Gsr tranny that has 60k and has no grinds, shifts very smooth. $700
99-00 SI shift linkage + shifter. $100
RMF style header. $500
Kenji chipped p28. $140(This does have a tunned base map of my ls/vtec motor and can be purchased at a discount with the motor.)
B-series axles + half shaft. $150
Inovative 96-00 ek motor mounts. $200
B-series starter. $50
obd2-a to obd-1 conv harness. $50
This motor is still in my car, i have not pulled it out yet. I will pulling it in the next week or 2. Im just trying to line up some sales before i pull it out.
These are the only pics i have uploaded at the moment. I have pics of the complete motor buildup and all parts that went onto it.
11.6cp
B18a block
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
Shot peened rods
micropolish crank
balanced bottom end
JG built B16 head
JG port and polish
3 Angle valve job
comitec head gasket
stock b16 cams
injectors
Distributor
Alternator
flywheel
$2300
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.coupe’s cream spinage »</TD></TR><TR><TD CLASS="quote">you going K jay? pmed</TD></TR></TABLE>
I didnt get your pm mike, send me another...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTI- »</TD></TR><TR><TD CLASS="quote">bump because my wheels are bad *** and im sending you all my buisness lol</TD></TR></TABLE>
much appreciated mang
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolfan020 »</TD></TR><TR><TD CLASS="quote">What crankshaft do you have gsr or ls? I need a gsr crankshaft, lemme know. Thanks </TD></TR></TABLE>
Its an ls crank, but im not parting the block. the motor is staying as a longblock or whole swap.
It's cool I was just wondering, I already have a built gsr motor I just need a new crank. Gl selling it though!
ekay. jay
Aug 12, 2007 09:45 AM
VNTEC
Mar 8, 2005 05:43 AM
