clutch fluid...
Old Aug 1, 2007 | 12:32 PM
lsvtecboi'95's Avatar
Default clutch fluid...
i just put a new slave cylinder and master cylinder and lines on my teg DC... since they are all new and there is no fluid in them.. what is the quickest and best way to fill the lines and cylinders and bleed them....?
i also need to replace the brake fluid in my brake lines... what is the best way to drain the and fill them back up..?
Old Aug 1, 2007 | 12:42 PM
DC4 Dave's Avatar
Bleeding brakes and clutches, like tipping over a Coke machine, is a two person job.
One on the pedal, one on the bleeder screw.
Old Aug 1, 2007 | 12:46 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: (DC4 Dave)
No way would such a general question be in the FAQ
https://honda-tech.com/zerothread?id=479958
Old Aug 1, 2007 | 01:08 PM
sorry bout the general question.... kinda new to HT...
how much do i need to unscrew the nipple...?
Old Aug 1, 2007 | 01:12 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: (lsvtecboi'95)
Not much. Untill fluid starts to come out.
Old Aug 1, 2007 | 02:22 PM
ok i tried to do all that and i am still not getting anything from the clutch pedal ...no resistance or pressure or bubbles or anything...
Old Aug 1, 2007 | 02:30 PM
IAcivicEK's Avatar
Banned
How many times are you pumping? you should be pumping by hand 10-15 times, and then unscrew the nipple( ) and fluid should come out. It probably will be bubbly considering air bubbles may be in the line.
Old Aug 1, 2007 | 02:33 PM
VTEC_PRODUCTION's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 Dave &raquo;</TD></TR><TR><TD CLASS="quote">Bleeding brakes and clutches, like tipping over a Coke machine, is a two person job.
One on the pedal, one on the bleeder screw.</TD></TR></TABLE>
actually you can self bleed...just buy the kit...i always work alone since i dont have much patience for other people so it comes in handy alot for me...
Old Aug 1, 2007 | 02:34 PM
should i just turn the nipple like a half turn or so... i see some fluid that dripps from the nipple threads when i unscrew it but still no bubbles or anything comin from the hose...
ccoake1
Honda Civic (2006 - 2015)
Jan 14, 2017 09:19 AM
ray.riddler92
May 4, 2011 01:00 PM
mugenspoongsr
Aug 2, 2006 03:14 PM
Brycen
Jan 9, 2006 05:49 PM
py1188
Apr 27, 2003 04:41 PM
