Civic hatch VX H22 fs/ft in LA, CA. Clean set up!!! new and best of everything
JUST CURIOUS TO SEE WHAT ELSE IS OUT THERE, ALL TRADES WILL BE CONSIDERED, DOESNT HAVE TO BE A INTEGRA. WILLING TO DO EVEN TRADE OR CASH ON TOP FROM ME OR YOU DEPENDS ON THE TRADE OBVIOUSELY!!
NEW HEADERS I WAS GONNA GIVE WITH THE CAR IS NOW INSTALLED, CHECK LAST PIC!!!
the car is a clean title civic hatch i just put this engine in about a year ago it has a carbon fiber hood and droped rolling on blacks with brand new tires, NEW RPS press. plate and clutch kit and NEW DSS axles stage 3 and LSD trany manual trans 99-00 si seats cd player w/remote and 4 JL Audio speakers sounds good, jdm cluster with rpm guage and FULL GSR disk conversion, new GSR master cyl. for brake and clutch steel braided lines for the brakes and clutch lines, carbon fiber hood, engine wire tuck and moroso alluminum oil pan 5 and half quart, brand new distributor and back up dist. , plugs wire greddy blue timing belt, 9.5 pound flywheel, unorthadox pully, new water pump and new 255l walbaro feul pump, and much much more! if u want to meet up somewhere and check each others cars out let me know. swap was done a nov or dec. of last year and i did everything myself , has a p28 ecu with crome pro Vtec at 4500.o ya, the car does have real jdm fenders with sidemarkers, not some off centered hack job holes cut and it has a real jdm rear spoiler with long LED, but if you want ill trade it with a white fiberglass duckbill wing.
if you are interested let me know thanks
92 Honda Civic VX Chassis, 1997 H22A4 complete motor GSR engine wire harness
OBD-2 to OBD-1 jumper harness configuration cleanest wire tuck (thanks to tony at Lockworks racing) PlaceRacing Motor Mounts Complete Black Interior w/ Momo Steering Wheel, JDM armrest, JDM headlights, JDM cornerlights JDM fenders w/ sidemarkers, Civic Dual Core Radiator, Slim Radiator Fan B&M Fuel Pressure Regulator Short Ram Air Intake Chipped P28 ECU tuned w/ Crome Pro, Front Strut Bar, Lower Tie Bar, Type R shift ****....Im tired of typing so there is plenty more
I would be willing to trade for integra 94 and up, must have A/C and as far as P/S i can give a rats *** about, if you have a AUTO or a 4 Door please dont waist my time. LOWBALLERS can go eff a Goat!! email me at Bigdady4@pacbell.net for pics untill i figure out how to add pics, i assure you it will be the cleanest engine swap you'll ever see and maintained better then me, will get a alot of parts with car to when sold
thanks for your time guys and girls
o ya, do i need to explain how Hard a H22 Pulls in a VX hatch. AND no joy rides
these last two pics was requested by someone that was interested and wanted to see the other side of the car and of the rear. and i will try to get compression reading soon
NOTE: i forgot to mention that i will give the stock rear tail lightes with the amber lights along with the white aftermarket lights that are on the car right now.
here are a few pics of the car and swap
Modified by bubblehead at 5:40 PM 9/14/2007
Modified by bubblehead at 12:24 PM 10/15/2007
Modified by bubblehead at 12:30 PM 10/15/2007
Modified by bubblehead at 2:51 PM 10/26/2007
Modified by bubblehead at 2:54 PM 10/26/2007
Modified by bubblehead at 3:04 PM 10/26/2007
just so you guys know i do have brand new headers with some special heat coating for the car that you will get with the car along with a few exhaustsw. 1 is stock with a cat and the other have a magna flow muffler on it, new header is a 2.5 if im not mistaken
car has a P28 with a crome pro on it, has a 2 step launch control for consistant launches and im sure you can set it up at a higher rpm then the 3000 or 3200 its set at now, if you had slicks and you go to the track i would suggest you do that, but with my new stock tires, its setup for minimul wheel spin! to make sure those puppies last for a while, tires are not cheap!
interior pics added...full interior, not sure on the milage on chassis and it doesnt say it on the pink slip. but I forgot to mention about 90 to 95% of the suspenstion bushings are pollyurathane and all wheel bearings have been done also, and to be honest i dont remember what suspension i have but i know with some 16" lo pro tires this car handles like it was riding on rails
pop up moon roof is threeway adjustable and can quickly be removed and have new waterpump, plugs, cap, rotor, plus a new distributor and new feul filter, greddy timing belt and balance shafts removed for quicker reving helps when balance shafts been removed plus the underdrive unorthadox pully plus the 9.5 lbs flywheel help the car rev much faster!
