CTR lsd tranny fluid?
Old Aug 1, 2007 | 11:43 AM
schuetts's Avatar
Default CTR lsd tranny fluid?
My S4C lsd tranny has a slight grind at higher rpms when shifting into 3rd. I'm going to change the fluid this weekend. Is there any specific fluid I need for an lsd trans? My 2 choices were either Honda MTF or GM/ pennzoil synchromesh. Any advice?
Also, if anyone could tell me the fluid capacity that'd be great too
Old Aug 1, 2007 | 11:49 AM
ru7's Avatar
ru7
I think u need 2l (i was told all b series trannys need 1.9l).
About the grind, i think the synchro needs to be replaced
Old Aug 1, 2007 | 01:03 PM
boostfreak20's Avatar
Pick up two liters and you'll be good. GM syncromesh is great stuff, I've used it in all my manual vehicles.
The OEM fluid is good too.
Old Aug 1, 2007 | 01:16 PM
94jdmeg6civic's Avatar
the new oem fluid FTW
Old Aug 1, 2007 | 01:18 PM
Hybrid96EK's Avatar
Default Re: CTR lsd tranny fluid? (schuetts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schuetts &raquo;</TD></TR><TR><TD CLASS="quote">My S4C lsd tranny has a slight grind at higher rpms when shifting into 3rd. I'm going to change the fluid this weekend. Is there any specific fluid I need for an lsd trans? My 2 choices were either Honda MTF or GM/ pennzoil synchromesh. Any advice?
Also, if anyone could tell me the fluid capacity that'd be great too </TD></TR></TABLE>
Synchromesh isn't going to cure worn teeth on a synchro. It might be easier for worn teeth to cut through, but you still haven't addressed the issue correctly. I would use nothing else other then Honda MTF. If the grind is still there after a fluid change (which it most likely will be) then its time to change the synchro.
Old Aug 1, 2007 | 07:09 PM
schuetts's Avatar
Default Re: CTR lsd tranny fluid? (Hybrid96EK)
Alright. Well I plan on fixing it this winter but was hoping that changing the fluid would help a bit till then. I'll change it anyways. Thanks for the replies everyone
Old Aug 1, 2007 | 07:56 PM
EG2Driver's Avatar
B16 trannies take 2.3 quarts last time i did mine...
Old Aug 1, 2007 | 08:07 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: CTR lsd tranny fluid? (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">B16 trannies take 2.3 quarts last time i did mine...</TD></TR></TABLE>
yep. you just have to drain it all the way. I pull the plug, go make some 'za and watch TV or do whatever else for 2 hours ...maybe hit up some internet ****....
Old Aug 1, 2007 | 08:09 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schuetts &raquo;</TD></TR><TR><TD CLASS="quote">Is there any specific fluid I need for an lsd trans?</TD></TR></TABLE>
No, but I'd recommend Redline MTL.
Old Aug 2, 2007 | 12:51 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: CTR lsd tranny fluid? (Blk00EJ8)
I'd suggest otherwise.......
Old Aug 2, 2007 | 01:38 AM
B serious's Avatar
Default Re: CTR lsd tranny fluid? (Mista Bone)
cant go wrong with HONDA MTF
Old Aug 2, 2007 | 12:21 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest otherwise.......</TD></TR></TABLE>
Why's that?
Old Aug 4, 2007 | 12:47 AM
Mista Bone's Avatar
D Tranny Guru
Redline MTL likes to breakdown the plastic bearing cages, this leads to failure.
Old Aug 5, 2007 | 04:58 PM
Blk00EJ8's Avatar
Default Re: (Mista Bone)
Is this speculation or is there evidence of this?
Old Aug 5, 2007 | 06:52 PM
b17what's Avatar
Default Re: (Blk00EJ8)
acura has their own version with synchromesh in it to help with the problems that the rsx's where having. I put it in my old da gsr that was starting to grind and it fixed it. Or at least quited it down a lot.
Old Aug 8, 2007 | 10:46 AM
niptek's Avatar
Default Re: (b17what)
i used honda mtf no grinds gonna change my fluid this week again
Old Aug 8, 2007 | 11:03 AM
speedooo's Avatar
Default Re: (niptek)
i used 10w-30 and i grinded 3rd, dropped that for the new honda mtf last week and the trans feels brand new. its a pretty awesome feeling when youre 15 year old trans feels brand new
laziebun
Transmission & Drivetrain
Feb 22, 2009 10:31 AM
SFWDcoupe
May 19, 2006 11:06 AM
patdemps
Jul 2, 2003 06:42 PM
dlric
Jun 15, 2002 05:14 AM
B18C5-EH2
Dec 16, 2001 04:52 AM
