gas tank replacement
Old Aug 1, 2007 | 11:36 AM
jamesc2123's Avatar
Default gas tank replacement
I have a '92 SI that needs a new gas tank. I took it in to a shop and they did what they could to patch it up but right now its sitting in my driveway with a bucket under it...
What I need to know is, if I went to a junkyard, is the gas tank for the 92-95 cars interchangable among body styles? Where I am, at least, it is very uncommon to find a hatch in a junkyard, much less an si, but can i take a tank off of a sedan or coupe. Also, do different spec levels, dx, ex, si etc, have different tanks?
Old Aug 2, 2007 | 06:19 AM
jamesc2123's Avatar
Default Re: gas tank replacement (jamesc2123)
bump, does nobody know anything about this?
Old Aug 2, 2007 | 06:27 AM
Syndacate's Avatar
I'd have to say yes..but I've never swapped it out in different body styles before...
Old Aug 2, 2007 | 06:52 AM
94hatchling's Avatar
according to alldata, all 1992-1995 gas tanks have the same capacity (11.9 gallons), but different part numbers between the CX/VX and DX/SI model hatches. BUT the DX/SI hatch shares the same part number as the 4 door and 2 door civics.
so as long as its not a tank from a CX/VX, i don't see any issues. hope that helped.
good luck!
Old Aug 2, 2007 | 07:10 AM
pythoner's Avatar
Default Re: (94hatchling)
the CX and VX have 10 gallon...I don't know of other difference thou...also delsol tanks are the same as the SI tank
Old Aug 3, 2007 | 03:24 AM
jamesc2123's Avatar
thank you, 94hatchling, that is exactly what i was looking for. Where did you find that out?
Old Aug 3, 2007 | 05:09 AM
pdiggitydogg's Avatar
Gas tanks at most junk yards are drilled and gas removed/syphoned. Yes, they probably realize they have drain plugs, but this is faster.
You will probably need to find a local seller, who is parting out a civic.
Old Aug 3, 2007 | 05:28 AM
t0p_sh0tta's Avatar
Default Re: (pdiggitydogg)
^ agreed. I also think it's safe to assume that all of the tanks are compatible as the chassis are the same.
integar94
Oct 23, 2008 10:51 PM
Eyal 951
Oct 4, 2006 01:59 PM
ThaCivicAssassin
12
Jun 16, 2006 06:08 PM
TheCiscoKid
16
Jan 22, 2004 05:27 PM
silverEH2
13
Apr 3, 2003 12:24 PM
