91-92 B1.8A1 start wont start
Old Aug 1, 2007 | 10:40 AM
wentcrazycrx's Avatar
Default 91-92 B1.8A1 start wont start
It was a live now it
Start then wont start
OBD0 84 crx with a 91-92 B1.8A1
It cranks just sometime it wont start
just code 15 ignition output signal
I cant find what this = ECU or igniter or??
I've check wire resistance, coil prm/sec If i could find a noid light check injection sys.
I've been working on this problem on and off for a weak while I'm pulling a sec b1.8A1
Help
I've been told that there's been a Igniter problem in B1.8A1 INT ENG is this true??
and yes it's in a 84 CRX but don't hold it against me please help
It's alive agine look down
Modified by wentcrazycrx at 9:50 PM 8/3/2007
Old Aug 1, 2007 | 10:50 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: 91-92 B1.8A1 start wont start (wentcrazycrx)
An 84 CRX with a b18 is nothing to hold against you. That would be one sick whip.
As far as your problem goes, are you getting spark? Fuel? Is the engine turning over strong?
Old Aug 1, 2007 | 11:09 AM
Default Re: 91-92 B1.8A1 start wont start (St Jimmy)
Spark is ok but not sher i think this is where my problem is??
got fuel pres at the filter and if i open the rail end plate there fuel
it cranks strong
I've been look for a noid light to check the ecu and injectors this would help rural out this part
You don't know when it will or won't start
Know it's a 1984 CRX with a 88 civic wringing harness OBD0 PR4 90-92 b1.8A1 was up and running Fuel pres was low 22-25 So changed the Pres reg AJ type up pres to 35 -39 and then it started to do this start won't start
Any thought.
No codes ....know it code 15
OK it cranks
IF it runs it runs but you dont know when it wont start
Modified by wentcrazycrx at 12:27 PM 8/1/2007
Modified by wentcrazycrx at 4:59 PM 8/1/2007
As of today 8-2-07 I've found a problem with the main relay If you number th plug like ECU plug
My ?? is Yel/Blk there two wires one to pump one to injectors pin 2 or pin 6
1 Grn/Blk two wires go to ecu pump input
2 Yel/Blk ???? pump or injectors
3 empty
4 Blk/Yel power in run /start
6 two Yel/Blk ???? pump or injector
7 Blk ground
8 Yel/Wht Power all the time
8/3/07
2 Yel/Blk fuel pump
3 empty
6 two Yel/Blk ECU/ injector
7 Blk ground
What i found was that power was not getting to the injector resistors
This is a 84 CRX with 88 wring harnes and a 91 B1.8A1 and one of the wires was not connected I rewried the main relay like a 90 integra main relay
ALL GOOD
Modified by wentcrazycrx at 10:00 PM 8/2/2007
Modified by wentcrazycrx at 9:42 PM 8/3/2007
bucknastty
Jan 15, 2012 12:49 PM
bboy_mikey
May 20, 2007 05:56 PM
Walshie
Jun 25, 2006 05:23 PM
rob42386
Sep 30, 2005 12:42 PM
blakryder1
Sep 11, 2004 10:04 AM
