Parts different from B16A and B18C???
Old Aug 1, 2007 | 10:14 AM
ken00si's Avatar
Default Parts different from B16A and B18C???
I swapped my B16A2 block for a B18C1 block and am putting the motor back together now. I was told that I would be able to use all of the parts because B-series parts are universal, but apparently this is not the case. Here's a list of B18C parts that I need so far:
Oil pan and gasket
Baffle plate
Oil strainer
Do you guys know if I need anything else? I just want to make sure I order everything now so I can get it done asap and not have to order more parts later.
Any help is much appreciated. Thanks!
Modified by ken00si at 1:29 PM 8/1/2007
Old Aug 1, 2007 | 10:21 AM
EL Vap133's Avatar
Default Re: Parts different from B16A and B18C??? (ken00si)
See if the part numbers match: http://www.slhondaparts.com
Old Aug 1, 2007 | 10:27 AM
ken00si's Avatar
Default Re: Parts different from B16A and B18C??? (EL Vap133)
I guess that would be the easiest thing to do, but there are tons of parts and I just was wondering if any of the motor swap guys knew off hand.
Old Aug 1, 2007 | 10:29 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si &raquo;</TD></TR><TR><TD CLASS="quote">I guess that would be the easiest thing to do, but I just was wondering if any of the motor swap guys knew off hand.</TD></TR></TABLE>
True. But sometimes you get the occasional "SEARCH YOU JERK" or something of that nature before a helpful person chimes in.
SOHC_me
Northwest (Sales)
Jun 17, 2007 01:46 PM
john_racer
Jun 14, 2004 02:31 PM
Hondasaurs
Mar 28, 2003 01:25 PM
LethalX
Jan 4, 2002 10:30 AM
