C5 Sedan stolen in Farmington Hills Michigan
Some time between midnight and 5 am this morning my car was stolen from independence green apartments.
Vehicle: 1995 Honda Civic Ex Sedan w/ ABS and sunroof and working cruise control.
Mileage: 190,xxx miles on chassis. 70,xxx miles on engine and transmission.
Mods:
Engine:
-B18C5 out of a 2001 Type-R that received a K swap.
-Spoon High Tension plug wires
-Denso Irridium plugs
-Apex-i header
-Custom test pipe
-Kteller 2.5" exhaust
-ES System Tuning oval muffler
-ITR radiator
-Chipped P28
-Cusco(?) catch can
-Spoon oil cap
-Spoon magnetic drain plug
Drive train:
-Spoon flywheel
-Exedy Stage 1 clutch
-Carbon coated blocker rings 3/4/5 waiting to be installed
Suspension:
-Apex-i N1 Type V coilovers w/ pillowball mounts, fronts not installed in picture (Being sent to Apex-i to be re-valved)
-Omni power front and rear camber kits
-Energy Suspension trailing arm bushings
Brakes:
-Willwood Dynalite 4-pot caliper w/ 11" drilled and slotted, vented two piece rotors
-New rear pads and rotors in trunk going on this weekend
-Both rear wheel bearings just replaced
-Two new wheel speed sensors will be replaced this weekend as well
Exterior:
-Rota A-Tech 15" x 7" wheels (Weds Sport replica)
-Dunlop FM901 tires
-Type-r style FRP front lip
-6000k HID's
-Factory style fog lights
Interior:
-Apex-i RSM
-Buddy Club bucket seat
-Schroth harness (never installed just draped over seat)
-ITR shift ****
-Factory 6 cd changer
Mods:
Engine:
-Apex-i header
-Custom test pipe
-ITR radiator
-Chipped P28
-Cusco(?) catch can
-Spoon oil cap
Drive train:
-Spoon flywheel
Suspension:
Brakes:
Exterior:
-Dunlop FM901 tires
-6000k HID's
Interior:
-Apex-i RSM
-ITR shift ****
ya some guy asked me yesterday out front of my apt. what year is your honda. He pulled up in a 05 tl with 22" wheels on it. I was kinda scared so I snapped a shot of his license plate just in case..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC IS UR BEST FRIEND »</TD></TR><TR><TD CLASS="quote">ya some guy asked me yesterday out front of my apt. what year is your honda. He pulled up in a 05 tl with 22" wheels on it. I was kinda scared so I snapped a shot of his license plate just in case..
Check it out, it may be worth it.
No alarm?
</TD></TR></TABLE>Check it out, it may be worth it.
No alarm?
Sedans usually aren't stolen because chances are they are basically stock.
Someone obviously knew you had a typie under there. For future, never rip on your car close to home. You are just asking for your car to get stolen. If you can't afford an alarm, install a kill switch. And if you can afford an alarm, install a kill switch anyways.
Just my 2 cents.
Just my 2 cents.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC IS UR BEST FRIEND »</TD></TR><TR><TD CLASS="quote">ya some guy asked me yesterday out front of my apt.</TD></TR></TABLE>
That's what happened to me two days ago.
I have an alarm, a kill switch, and i have a club. If they want it they will get it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC IS UR BEST FRIEND »</TD></TR><TR><TD CLASS="quote">well my window is right there so i look out a hundred times but I do have viper alarm 5900 sst which will be installed shortly
My car was no more than 15 feet from where I was sleeping. If they started it they didn't do it where it was parked.
</TD></TR></TABLE>My car was no more than 15 feet from where I was sleeping. If they started it they didn't do it where it was parked.
man expletive this is the 2nd car stolen in 3days even thou im up in toronto ppl down in the states are crazy **** when will this end
*edit* i say theifs caught get one ball cut off
sorry bout the loss from what i could see you loveed the **** out of the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scrooge »</TD></TR><TR><TD CLASS="quote">man expletive this is the 2nd car stolen in 2days even thou im up in canada toronto ppl down in the states are crazy **** when will this end
true
</TD></TR></TABLE>true
im trying to get grey interior from a eg9 4 door 92-95 too. If i see ur 4 door i swap the interior real quick then give it back to ya. It may have tan interior. Im just kiddin bro. Best of luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
I have an alarm, a kill switch, and i have a club. If they want it they will get it.</TD></TR></TABLE>
Daaaaammmmnnn, thieves are ******* shady. They probably yanked your hood, disconnected your battery then rolled it until they could start it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
Daaaaammmmnnn, thieves are ******* shady. They probably yanked your hood, disconnected your battery then rolled it until they could start it.</TD></TR></TABLE>
I'm sure a simple tow truck, would suffice....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii »</TD></TR><TR><TD CLASS="quote">Sedans usually aren't stolen because chances are they are basically stock.</TD></TR></TABLE>
This is a common misconception, and a dangerous one to have if you want to keep your Civic sedan.
Just recently there was a 6th gen sedan that was stolen and mentioned in the 6th gen sedan thread. People kept saying they didn't think anyone would steal their car, because it was a sedan. So they didn't bother to get an alarm or anything because only coupes and hatches need those.
Sedans do get stolen. If your car is clean, there's more chance that you have an engine swap or at least some JDM goodies somewhere that could be taken.
His car was clean, had Rotas, had Wilwood brakes, drilled and slotted rotors and Buddyclub seats. He has enough showing for someone to steal. An engine might just be a nice surprise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii »</TD></TR><TR><TD CLASS="quote">I'm sure a simple tow truck, would suffice....</TD></TR></TABLE>
Except that not everyone has or has access to a tow truck. Rolling it out is just a cheap way of doing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspireAZN »</TD></TR><TR><TD CLASS="quote">my sedan got stolen on the 22nd
Your car was the sedan I was referring to.
I wonder what percentage of H-T members have had cars stolen, and out of those people, what cars were most often stolen. It'd also be interesting to know if said cars were stock, lightly modified or highly modified and what percentage of stolen cars had security.
</TD></TR></TABLE>Your car was the sedan I was referring to.
