Help needed, New Clutch and Flywheel but still slipping
Old Aug 1, 2007 | 06:33 AM
rebelwocause's Avatar
Default Help needed, New Clutch and Flywheel but still slipping
Installed new CenterForce Dual Friction clutch with Fidanza Flywheel after car had problems with not engaging the clutch. The clutch was toast. After installing with proper torque specs and adjusting the pedal and clutch, the clutch still slips. The car starts to move, the clutch seems to engage but then stops moving the car. The clutch makes a noise kind of like a "howl".
My signature shows the car specs. Is this a problem with the ATTS or tranny or is there something else I need to look at? Can anyone tell me what the problem may be or what to look for?
Old Aug 1, 2007 | 06:45 AM
gogunkergorilla's Avatar
Default Re: Help needed, New Clutch and Flywheel but still slipping (rebelwocause)
check for leaks around the clutch master cylinder and slave cyulinder....did you bleed if???bleed like a gallon of fluid through it so you are sure there are no air bublles in the system.
Old Aug 1, 2007 | 07:15 AM
94Vtecluder's Avatar
Default Re: Help needed, New Clutch and Flywheel but still slipping (gogunkergorilla)
You might have spilled some oil on the clutch/flywheel. It should cook off in time.
Old Aug 1, 2007 | 09:42 AM
M2B4's Avatar
Default Re: Help needed, New Clutch and Flywheel but still slipping (94Vtecluder)
Did you spray the pp with brake cleaner? my clutch was toast too and just cleaned the parts and installed. i didnt even bleed or adjust pedal.
immalooser
Apr 14, 2010 08:01 PM
25Type-s
Oct 22, 2006 08:33 AM
Chiller
Apr 10, 2005 10:52 PM
t04ecvc
Apr 20, 2004 03:38 PM
abeaujuin
Jan 9, 2004 04:43 AM
