Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
hissing noise from compressor area after shutting car down... normal?
Old Aug 1, 2007 | 06:09 AM
justinatlga's Avatar
Default hissing noise from compressor area after shutting car down... normal?
hi all
i am getting a used 2006 Honda Civic, about 41k miles (I know that's quite a bit). The car has clean CarFax history, and was acquired by the used car dealer directly from Honda Motors and was previouly used in their leasing fleet.
i took the car to a car shop to have it checked up; everything was fine except for a hissing noise that's coming out around the compressor area. The mechanic initially thought it could be a freon leak; but after diagnosing, it was not. The noise goes away after the car shuts down for about 20 minute. Is this normal? or should I worry about potential problems developing down the road?
Thanks much for any information you could share!
jt
Old Aug 1, 2007 | 06:14 AM
Type X's Avatar
Default Re: hissing noise from compressor area after shutting car down... normal? (justinatlga)
the sound is for 20 minutes?
maybe a bad seal ? run the system on max a/c and check the lines while running
Old Aug 1, 2007 | 06:46 AM
Shiftyshadee's Avatar
It's the Evaporative system purging. If you have the car up in the air (IE changing your oil on a lift) it actually sounds like it's coming out of the oil pan.
Nothing is wrong with your car.
Old Aug 1, 2007 | 10:30 AM
Tam N's Avatar
Default Re: hissing noise from compressor area after shutting car down... normal? (Shiftyshadee)
Mine does the same thing for a few minutes on a hot day with the AC running
Old Aug 1, 2007 | 11:03 AM
misterghost's Avatar
mine too...and been since day one...no problems so far.
Old Aug 1, 2007 | 11:29 AM
EK k kay's Avatar
Default Re: (misterghost)
Same here on my LX although not as long as 20 minutes.
cdero
Aug 27, 2014 06:49 PM
jrock1234
Jun 4, 2012 12:26 PM
skaternak
Jan 30, 2010 10:25 PM
muhaMan
May 14, 2007 07:07 PM
mattL
Jul 19, 2002 06:23 AM
