97 accord 2dr side moulding removal
Quick Noob Question. I try to search but the search function currently doesnt work. How do you go about removing the rubber moldings on the drivers side door that goes to the rear panel? If someone can give me the proper steps that'll help.
The side moulding is principally held on with adhesive tape. But there is a plastic clip near the front of the door, and a plastic nut near the rear of the door (so, you have to remove the door panel to get to the nut). -- Otherwise, it is just prying the moulding off with a screwdriver (put some masking tape on the tip of the screwdriver to help not scratch the paint on the door, you might also want to put some masking tape above and below the moulding too).
Elitehero36
Aug 5, 2016 01:33 PM
Bakado
Jun 10, 2012 10:12 PM
tom48
Oct 17, 2007 09:05 PM
