2.5" collector gasket
just spoke with my dealer and ordered the legend cpe exhaust donut
can anyone confirm the right number ? sometimes I secong guess the dealers around here - thanks
Part no 18229-spo-j51............anyone confirm this ?
Acura (from an early 90's Legend coupe) - 18229 SPO J51
Honda (from the S2000) - 18229 PCX 003
http://itr-nc.com/pages/jdm_4.htm
Dodge Neon ? are you for real ?
I think I got the right one , it was like 24 bucks with my dealer discount so I should be good , find out on friday I guess
jamie - who thinks willard only says neon cause he really wants one Yo!
I grabbed a Neon flange gasket off a junked car..... I let a friend use it on his JDM 4 into 1 header and I did not hear any complaints.
not sure about the year of the Neon...
Will
Will
Jamie, I orderd the S2000 one from shockley and Paul has the Legend one. Both are idential parts, we payed $24 for each one and they fit like a glove. By the way, the 4-1 and carsound are
Oh and one other thing. ITR rear strut bar and JDM ITR (yes 23mm) sway bar are on the way. KYB AGX's are on. Calling Ground control for springs...your opinion. 300f/400r? What are the max those struts will handle. I'm assuming up to 500lb?
Thanks.
Thanks.
um , 400 is max on the AGX's
with the 23 rear bar and the car not totally slammed it should be quite nice
I think that sounds like a good combo
I think your stock front spring rates are 200 , maybe a little more
I would see if you can find the rates from GC and go from there
just go 100-150 lbs above the front and that should be a good place to start
Eklsv-t
Jan 9, 2008 07:22 AM
Crisgo
May 18, 2004 03:05 PM
Drinker
