94 civic cx 3dr stock (headers 4-2-1, exhaust, intake)
Old Jul 31, 2007 | 10:32 PM
n2imprts21's Avatar
Default 94 civic cx 3dr stock (headers 4-2-1, exhaust, intake)
okay please dont laugh at me i kno i should kno this stuff if im going to own a honda but i dont.. i got my car from my parents who bought it from a wrecking yard. its a 94 civic cx 3dr with stock motor only thing it has is exhaust headers and short ram intake. it needed a new engine when my parents bought it along with new clutch. my uncle replaced the transmission. i allowed a friend to drive my car along with me. now this friend knew about the bad motor and the bad clutch. well make a long story short for some odd freakin reason he drops the car from 5th to third on the freeway leading to throwing a rod and obviously blowing the engine.. well i found an engine
A D15B SOHC VTEC ENGINE ONLY HONDA CIVIC 92-95
Item Description
• IMPORTED FROM JAPAN
• Make: Honda
• Engine Code: D15B
• Year: Honda Civic 95-95
• Valve Train: SOHC, V-TEC, 16 Valve
• Horse Power: 125hp@6600rpm
• Torque: 106lbs-ft@5200rpm
• Redline: 7000rpm
• Displacement: 1590cc
• Mileage: Approximately 25-35 Thousand Miles
• Condition: Best
• Included: Complete Motor
Complete Head & Block
Distributor, Intake Manifold
Exhaust Manifold, Alternator
Power Steering Pump
Fuel Rail, Injectors
Throttle Body, V-TEC Solenoid
https://www.tigerjapanese.com/...d=154
what will i need for this??? the friend that blew my engine is telling me nothing will match up??? is this true and if so where can i get a cheap motor that will???
Old Jul 31, 2007 | 11:39 PM
pacific17's Avatar
Default Re: 94 civic cx 3dr stock (n2imprts21)
that would be a straight swap.. because a 94 civic cx hatch has a d15b7 for stock..
Old Jul 31, 2007 | 11:44 PM
n2imprts21's Avatar
Default Re: 94 civic cx 3dr stock (pacific17)
but can i use it?? will everything match up right???
Old Jul 31, 2007 | 11:52 PM
blake_mp's Avatar
the JDM D15B has a diff ECU for the V-tec-E, yes it will work. check out D-series.org they can answer all your questions
Old Jul 31, 2007 | 11:59 PM
n2imprts21's Avatar
Default Re: 94 civic cx 3dr stock (blake_mp)
oh ok... thanks!!!
coupeaddix93
Mar 2, 2012 11:02 AM
coupeaddix93
Mar 2, 2012 10:54 AM
