Extreme vibrations when idle
Old Jul 31, 2007 | 06:56 PM
js593's Avatar
Default Extreme vibrations when idle
When im idle, in drive, or reverse, or sitting at a traffic light, i feel so much vibration in the cabin, i swear something is going to fall off. I have noticed today that the front motor mount is actaully able to move side to side, but not up and down, etc... If it moves side to side, i would think there is too much slack and it should be replaced no? If not, which other mount could it be, (i checked the one under the Air intake box, and it seeems stuff, next to no movement, and the top left side engine mount is also very stiff as well. Please note that its a 1990 with next to no rust anywhere (except the wheel well on the driver side (litterally NO floor boards are rusted at all, and none of the frame has any rust on it (im going to get an undercoat job as well))
Old Jul 31, 2007 | 07:09 PM
Hammer99ex's Avatar
Default Re: Extreme vibrations when idle (js593)
i had this happen to me on my first car... chevy lumina... ne way... turned out to be a cracked flexplate.. if your car is an automatic, keep this thought in the back of you mind incase nothing else yields results
Old Jul 31, 2007 | 07:11 PM
js593's Avatar
Default Re: Extreme vibrations when idle (Hammer99ex)
Flexplate? (say what?) Never heard that term before (haha wow, i sound like a total NOOB, Im used to basic model saturns and GM's not honda's, im totally new to this.
Old Jul 31, 2007 | 07:42 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by js593 &raquo;</TD></TR><TR><TD CLASS="quote">Flexplate? (say what?) Never heard that term before (haha wow, i sound like a total NOOB, Im used to basic model saturns and GM's not honda's, im totally new to this.</TD></TR></TABLE>
Flexplate in all cars is equivelant to a pressureplate for manual cars
Old Aug 1, 2007 | 06:29 PM
js593's Avatar
Default Re: Extreme vibrations when idle (awdgsx96)
Ah cool, learn something new every day, The mount itself is VERY flexable, and its the OEM original one from 1990, (or earlier depending when it was made) So im going to start off with that, it was only 85 CAD my price, and when you work at an auto parts store, it helps alot, nearly 100 bucks off. I just got the gas tank in *WOOT* and it runs too... However im running into an issue now, When it started up, the rpm's started to fluxuate a bit, it would go up to about 2k, then drop to 1500, then under 2k, drop to 1500, and it would do this until its fully warmed up, any idea what sensor might be causing this issue?
EDIT: I should also add, if i immdiatly put it into gear (auto tranny) it stops.
Tachi
Aug 9, 2015 09:45 AM
brandon400hp
Honda Civic (2001 - 2005)
May 30, 2010 04:33 PM
emmaturecb7
Jan 10, 2008 04:56 PM
m1ndless
Jul 30, 2007 07:51 PM
