Portflow Retainers take part two.
Old Jun 11, 2002 | 04:07 AM
B18CXr's Avatar
Default Portflow Retainers take part two.
See for yourself......
http://www.reddotmotorsports.com/~jack/ti/index1.htm
[Modified by B18CXr, 8:10 AM 6/11/2002]
Old Jun 11, 2002 | 04:28 AM
D's Avatar
D
Default Re: Portflow Retainers take part two. (B18CXr)
Nice.
Old Jun 11, 2002 | 04:29 AM
Willard's Avatar
Default Re: Portflow Retainers take part two. (D)
"it's a wear item"
Will
Old Jun 11, 2002 | 04:33 AM
Mike K's Avatar
Default Re: Portflow Retainers take part two. (Willard)
Stock retainers kick ***, y0.
Old Jun 11, 2002 | 05:32 AM
MackSpeed-616's Avatar
but these are race parts... i thought they are supposed to deliver higher performace than stock for a similiar cost for an unlimited amount of time and i never have to replace them....and when i melt them they turn to gold!
[Modified by Sexual Chocolate-616, 10:44 AM 6/11/2002]
Old Jun 11, 2002 | 06:43 AM
Mike K's Avatar
Default Re: Portflow Retainers take part two. (Sexual Chocolate-616)
lol.
oh, and you also forgot that the company is supposed to pay for your engine when the part fails.
Old Jun 11, 2002 | 06:45 AM
Default Re: Portflow Retainers take part two. (Mike K)
lol.
no
HONDA pays dummy
Old Jun 11, 2002 | 08:36 AM
B18CXr's Avatar
+kumquat
Old Jun 11, 2002 | 10:02 AM
Willard's Avatar
http://www.corrosionsource.com/handb.../cps_a_frc.htm
Fretting corrosion is corrosion that can occur on the load bearing contact surface between mating material. It is caused by the combination of corrosion and the abrasive effects of corrosion product debris often seen in equipment with moving or vibrating parts. Other problems induced by fretting corrosion include: surface pitting. seizing and galling of mating surfaces. reduced fatigue life as a result of stress concentrations produced on the metal surface.
Old Jun 11, 2002 | 10:14 AM
obd2gsr's Avatar
did all the retainers look like that? is it from the intake or exhaust side? how many miles? how many retainers ended up like that? that's some wear and tear.
[Modified by obd2gsr, 7:15 PM 6/11/2002]
Old Jun 11, 2002 | 10:24 AM
B18CXr's Avatar
all looked this way
30Kish miles on B's and Toda springs, oil change every 1,500 miles
Old Jun 11, 2002 | 10:58 AM
pinota's Avatar
Hummm, i have Portflow retainers and Toda valve springs to install on stock cams.
Do you think i´ll have those problems too ?
Pinota
Old Jun 11, 2002 | 11:45 AM
sgT's Avatar
sgT
Default Re: Portflow Retainers take part two. (pinota)
you dont want to use aftermarket springs with stock cams.
You will just lose power. no real advantage with stock cams
Old Jun 11, 2002 | 11:48 AM
Johnny Tran's Avatar
Pinota
the voice of wisdom
i would make a top speed run or two......just to "seat" the retainers
Old Jun 11, 2002 | 11:53 AM
B18CXr's Avatar
Default Re: Portflow Retainers take part two. (Johnny Tran)
OMG is that some funny chit!!!!!!!
Old Jun 11, 2002 | 11:58 AM
Back in Black's Avatar
Rather OG
LOL...
Old Jun 11, 2002 | 12:11 PM
D's Avatar
D
HAHAHAHA.. nice.
D
Old Jun 11, 2002 | 02:09 PM
pinota's Avatar
I want to raise the fuel-cut limit to 9100 rpm.
My ITR goes really fast to the fuel cut off in all gears at 8650 rpm, i want to raise it a bit.
I want to raise it safely.
Do you think i´ll lose hp ? what do you mean ?
Pinota
Old Jun 11, 2002 | 02:26 PM
sgT's Avatar
sgT
stock cams require stock springs.
more spring pressure = more work to move the valves = less power output
stock springs are all you need.
Old Jun 11, 2002 | 02:31 PM
pinota's Avatar
Default Re: Portflow Retainers take part two. (sgT)
I see.
Thanks fo the info.
Old Jun 11, 2002 | 02:38 PM
JDM_DOHC_SiR's Avatar
New User
damn thats sound slike stuff out of the Navys NA-01-1A-509 manual ...
Old Jun 11, 2002 | 04:00 PM
EagleR's Avatar
Default Re: Portflow Retainers take part two. (JDM_DOHC_SiR)
Probably is out of there...the navy has a manual for every thing on earth....
Old Jun 11, 2002 | 04:07 PM
New User
Default Re: Portflow Retainers take part two. (EagleR)
Tell me about it I deal with the Navy's **** Every Damn Day
maischi
Dec 1, 2002 05:28 PM
Tetsuwan Atomu
Nov 29, 2002 06:55 PM
hondanacura4life
Nov 11, 2002 05:49 PM
SiRkid
Nov 7, 2002 08:15 PM
eg_nezay
89
Sep 20, 2002 08:58 PM
