Floating Gas needle
Replace your gas tanks bearings and regrease the boots on them too. Might also check your lower gas tank shock absorber units, and then if none of that works maybe just <U>slow down around the turns?! </U>
[It's normal for your needle to waver when you go on sharp exit ramps, hills, curves, etc., but I really wouldn't worry about it. If your level is okay before you go into a turn, you probably won't run out of gas by the end of the turn...]
Yeah that's normal as your gas level shifts from side to side the sensor will get different readings. Only way to fix it would be to measure you gas in a different matter. Unless you gas needle is swaying like 1/2 a tank on normal driving, I really wouldn't worry about it. I actually feel pretty good about it when I think I'm almost out of gas but don't want to stop yet, and I take a ramp that pushes me up to a 1/4 tank.
Tha_liks
Jan 27, 2011 05:19 PM
