Will 92-95 shocks fit an ek?
Old Jul 31, 2007 | 04:48 PM
socale39's Avatar
Default Will 92-95 shocks fit an ek?
I accidentally bought 92-95 shocks however upon replacing I noticed that the rear shocks are slightly different not allowing me to install. I recently was cruising through some photos and saw a member using 92-95 rear shocks on his 96 but I feel the problem is that the suspension couldn't compress/extend without the shock hitting the lca. Any insight would be appreciated. Thanks
Old Jul 31, 2007 | 05:03 PM
oxSLEEPERxo's Avatar
Default Re: Will 92-95 shocks fit an ek? (socale39)
it will fit, just have to use washers in between the shocks on both side
Old Jul 31, 2007 | 05:26 PM
socale39's Avatar
Default Re: Will 92-95 shocks fit an ek? (oxSLEEPERxo)
I was having trouble installing because of the slightly shorter bolt hole location. Do you guys but a load on the car while installing to straighten out the lca and make room to install?
Old Jul 31, 2007 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socale39 &raquo;</TD></TR><TR><TD CLASS="quote">I was having trouble installing because of the slightly shorter bolt hole location. Do you guys but a load on the car while installing to straighten out the lca and make room to install?</TD></TR></TABLE>
you got to get longer bolts
koumatae
Suspension & Brakes
May 12, 2012 09:18 PM
wakaranai
Oct 14, 2007 12:46 PM
spoonfed407
Jul 23, 2004 08:33 AM
ImprtTuner88
Dec 6, 2003 10:25 AM
FrostyDC4
May 1, 2003 05:31 PM
