Hot Armrest Area!!
Old Jul 31, 2007 | 03:39 PM
MDM's Avatar
MDM
Default Hot Armrest Area!!
does anyones armrest seem hot, or is this normal?? the thing is averytime i drive around for a while, hot air starts coming out around the radio, armrest, shifter, and e-brake area.
i was just wondering if its normal or sumething is really getting hot down there!!
it aint normal hot, its HOT!!!
any help appreciated Thanks!!
Old Jul 31, 2007 | 03:45 PM
BlackoutVTi's Avatar
Default Re: Hot Armrest Area!! (MDM)
It's normal in hot weather for that to happen, but you could be the first to rig a complete system of internal cooling fans to keep the superstructure of the car well ventilated...
Old Jul 31, 2007 | 03:46 PM
MDM's Avatar
MDM
Default Re: Hot Armrest Area!! (BlackoutVTi)
lol yea thanks haha
Old Jul 31, 2007 | 03:50 PM
n1_egsex's Avatar
* B A N N E D *
it's your exhaust dude hah
Hans Moleman's Avatar
From: The Place that everybody call the southland on the, SPLA
Be careful, it might catch fire.
Old Jul 31, 2007 | 03:56 PM
MDM's Avatar
MDM
Default Re: Hot Armrest Area!! (Hans Moleman)
maybe huh
seriously so its normal??
i mean its really hot no joke..
Old Jul 31, 2007 | 04:11 PM
Well, is your exhaust mounted relatively close to your civic body? Because that may be generating the excessive temperatures that you seem to be worried about. However, I don't think you'll be having any serious problems. You could check underneath your car to see if there's any heat damage to your shifter bushing as well.
Also, is there evidence of excessive heat like that which you've described during colder weather as well?
Old Jul 31, 2007 | 11:54 PM
NOFX's Avatar
H-T White Ops
My stock exhaust has put off this heat since I got the car over four years ago. It's normal.
Old Jul 31, 2007 | 11:56 PM
blake_mp's Avatar
Default Re: (NOFX)
find a stock heat shield
Old Aug 1, 2007 | 03:34 AM
imcunner's Avatar
when i had my old 4door it happened
Old Aug 1, 2007 | 03:54 AM
NOFX's Avatar
H-T White Ops
Default Re: (blake_mp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blake_mp &raquo;</TD></TR><TR><TD CLASS="quote">find a stock heat shield</TD></TR></TABLE>
Almost forgot about that. Shortly after I bought my Civic (from the northeast), the heat shield fell off. It actually happened Christmas Eve as I was leaving a friend's house. It started dragging on the ground suddenly. I now have new piping to replace the rusted stock stuff, but it's all stock spec (just stainless now!).
A new heat shield might help, but it's not really something bothersome to me.
Old Aug 1, 2007 | 07:57 AM
MDM's Avatar
MDM
Default Re: (NOFX)
Thanks guys.. yea it doesnt really bother either i was just concerned if it was something not normal.. and in the winter the same thing does happen except a little cooler but it feels good when its cold
so if i get new piping will that stop or do i still need a heatshield??
Old Aug 1, 2007 | 09:23 AM
bpkmrtoes's Avatar
Default Re: (MDM)
cars aren't supposed to be totally sealed. they're designed to have some airflow to bring in some fresh air. maybe this is what you're experiencing?
Old Aug 1, 2007 | 09:36 AM
MDM's Avatar
MDM
Default Re: (bpkmrtoes)
it aint fresh, thats for sure!!
Old Aug 4, 2007 | 01:06 AM
bpkmrtoes's Avatar
Default Re: (MDM)
maybe it used to be an automatic and they cut the dip that used to be there?
Old Aug 4, 2007 | 10:16 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes &raquo;</TD></TR><TR><TD CLASS="quote">maybe it used to be an automatic and they cut the dip that used to be there?</TD></TR></TABLE>
I'm not sure what dip you mean, but anyway...
Mine is a manual and has always been a manual.
The seventh digit of your VIN will tell you what it was from the factory.
The following info is from Honda.
Body & Transmission Type
1: 2Dr. Coupe, M/T
2: 2Dr. Coupe, A/T
3: 3Dr. Hatchback, M/T
4: 3Dr. Hatchback, A/T
5: 4Dr. Sedan, M/T
6: 4Dr. Sedan, A/T
7: 5Dr. Wagon, M/T
8: 5Dr. Wagon, A/T
Old Aug 4, 2007 | 11:44 AM
MDM's Avatar
MDM
Nah it was my uncles he got it manual from the dealer<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
1: 2Dr. Coupe, M/T
2: 2Dr. Coupe, A/T
5: 4Dr. Sedan, M/T
6: 4Dr. Sedan, A/T
7: 5Dr. Wagon, M/T
8: 5Dr. Wagon, A/T</TD></TR></TABLE>
Old Aug 4, 2007 | 12:24 PM
bpkmrtoes's Avatar
Default Re: (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Wind Plate!
Now you have the path that the auto cables go through and you probably test fitted your shift linkage up to it and was like "what the hell this thing is in the way" well thats correct it is. What to do is cut it out with your dremmel. You have 2 choices, 1. make a plate or 2 drive with a big hole, and lost of road nose and exhaust heat.
There is going to be a heat shield in the way, take off that heat shield and if you want to do what i did your going to cut a piece of that for your plate. Cut your hole as close to the chassis as you can. The smoother the better. Grind down the paint a little so the harden stuff can stick better. Also grind down the plate so it sticks good, but do both sides of it. Now when you got it nice and clean put your Goop on the bottom and press it up to the chassis until it settles. When it settles take your Quick Steel and spread it all around and get all the gaps. and let it harden and then your set, no road heat
but since you've said it's always been a manual, i don't know. Good Luck with it.
ref:: Auto to Manual Swap in full detail!!
https://honda-tech.com/zerothread?id=1337459
Old Aug 4, 2007 | 12:38 PM
angrysmileyface's Avatar
I have a 93 EX coupe and the resonator rusted off beneath the ebrake. The console is warm and can be sometimes hot if I have been running all day with it. Currently I am just driving with the window down until I can replace the pipe just to let fresh air in..
Old Aug 4, 2007 | 04:48 PM
MDM's Avatar
MDM
Default Re: (angrysmileyface)
yea ill see but thanks everyone
Old Aug 4, 2007 | 07:05 PM
ariza034's Avatar
yup
weaponrcs
Northern California
Jul 14, 2008 10:05 PM
jsnm
Jun 29, 2005 12:19 PM
xkhalil333x
Sep 9, 2003 02:07 PM
bluemex
Aug 24, 2003 02:20 PM
