WTB: GSR / ITR complete long block....ALABAMA !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Down Shift Motoring »</TD></TR><TR><TD CLASS="quote">i have ctr long block pm me</TD></TR></TABLE>PMd
i got a ls-vtec longblock. asking 1000. i made 192 horse all motor and 254 horse nitrous. everything is stock.
Ls/vtec complete longblock:
11.6cp
B18a block
Pr3 pistons + new rings
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
acl main, rod, and thrust bearings
Bored .20 over + fresh hone
Shot peened rods
micropolish crank
balanced bottom end
JG built B16 head
JG port and polish
3 Angle valve job
supertech valves,springs,retainers
comitec head gasket
stock b16 cams
skunk2 adj cam gears
spoon style calve cover
ITR intake manifold/b16 TB
The longblock will come with the following:
injectors
all sensors(iat, iacv, map, tps, ect ect)
Distributor
fuel rail/fpr(stock)
ngk sprak plugs + wires
Alternator
flywheel
6 puck TCS clutch and pressure plate
$2300, this a a 200+whp motor
I can also include axles, shift linkage, mounts, whatever you need.
11.6cp
B18a block
Itr oil pump
gsr water pump
gsr timing belt
gsr belt tensioner
arp rod bolts
arp head studs
Shot peened rods
micropolish crank
balanced bottom end
JG built B16 head
JG port and polish
3 Angle valve job
comitec head gasket
stock b16 cams
injectors
Distributor
Alternator
flywheel
ekay. jay
Southeast (Sales)
19
Aug 30, 2007 03:29 PM
ekay. jay
Aug 12, 2007 09:45 AM
Ag-Eng
Oct 6, 2003 04:15 PM
