DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification?
Old Jun 11, 2002 | 01:53 AM
PYITR821's Avatar
Default DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification?
I have an 01 itr and I was wondering if I were to get the DC JDM 4-1 and a Carsound Cat, would I be able to just bolt these on without any modification? And what about the size of the Cat outlet that the exhaust bolts to, would I still be able to bolt a Apexi N1 to it?
Old Jun 11, 2002 | 01:58 AM
PYITR821's Avatar
Default Re: DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification? (JUNtypeR)
I also live in California, would I have any problems with smog(ie. visual, sniffer)?
Does anyone have any pics of a DC JDM 4-1?
[Modified by JUNtypeR, 11:01 AM 6/11/2002]
Old Jun 11, 2002 | 04:07 AM
StageOne's Avatar
I beleive the answers are here:
https://honda-tech.com/zerothread?id=204632
Old Jun 11, 2002 | 06:55 AM
PYITR821's Avatar
Default Re: DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification? (StageOne)
Thanks, but I have one more question. With this setup will I have any problems passing the visual and the sniffer test for SMOG?
Old Jun 11, 2002 | 07:21 AM
azn98R's Avatar
You should be ok....I'm still driving around with my test pipe hehehe....
Selling my carsound cat, but I think it will only fit 97 & 98 ITR's.
Old Jun 11, 2002 | 07:27 AM
nsx-Animal's Avatar
Default Re: DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification? (azn98R)
Yes it's just plug and play
Old Jun 11, 2002 | 07:31 AM
PYITR821's Avatar
Default Re: DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification? (Itr-Animal)
What about SMOG?
Old Jun 11, 2002 | 07:32 AM
sackdz's Avatar
Smog? What's that?
Old Jun 11, 2002 | 07:34 AM
PYITR821's Avatar
Default Re: DC JDM 4-1 and Carsound Cat: Would these just bolt in without modification? (sackdz)
EMISSIONS TEST!!!!
Old Jun 11, 2002 | 07:35 AM
sackdz's Avatar
Emissions test? What's that?
Old Jun 11, 2002 | 07:39 AM
PYITR821's Avatar
Nevermind.
Old Jun 11, 2002 | 07:44 AM
azn98R's Avatar
think he is being sarcastic F*** emissions, hehe, j/k you should be ok
Old Jun 11, 2002 | 10:44 AM
SurferX's Avatar
Most likely you will fail the visual. If you can get past that then you will probably pass the test as long as the cat is fairly new. The coating on the Carsounds I've been told will wear out after a year or two.
Old Jun 11, 2002 | 10:57 AM
underrated99si's Avatar
You will fail the visual because of no CARB# on the header and is intended for Offroad use but I would not worry about it just get the rear cat flange moded and have fun with it and when the smog day comes put back to stock. I ******* hate the state ref they fucked me royal even with Carb certified parts
J-g-D-s-M-r
Oct 13, 2003 09:04 PM
mugenracer
Mar 26, 2003 05:05 PM
tweekerz
May 10, 2002 11:59 AM
Adampops
Dec 16, 2001 07:28 PM
