Pioneer, Matrxx Audio stuff. Good Quality Goods
Old Jul 31, 2007 | 01:32 PM
ReDemoN's Avatar
DixielandImports Please
Default Pioneer, Matrxx Audio stuff. Good Quality Goods
Here is goes:
First up is door speakers.
I have four Pioneer 4-way 6 1/2's
Model number: TS-S1680R
50 Shipped for EACH pair.
2nd
Two Pioneer 4-way 6x9's
Model Number: TS-A6980R
Next is the amps.
These are some high end amps.
They hold the world record in SPL right now.
First I have two MATRXX MXP-600S
It will hold 1 ohm
I ran 4 Speakers with each one.
There pretty badass.
260 Shipped EACH.
Specs:
Unique design provides high-density circuit layout and superior vibration resistance.
Each part is tested for accuracy and tolerance during assembly.
Power: 90Wrms x 2 @ 2 ohms, 150Wrms x 2 @ 2 ohms, 300Wrms x 1 @ 4 ohms (mono)
Peak power: 600W x 1 @ 4 ohms mono
Frequency Response: (-3dB) 10 Hz to 25kHz
Signal to Noise Ratio: 105 dB A weighted
Distortion at full rated output: 0.1% THD+N
Damping Factor: >125
Input Sensitivity: 150 mV to 4 Vrms
Idle Current: 1 amp
Dimensions LxWxH : 9"x 9 ¼" x 2 1/8"
2nd
This is the bad boy
A MATRXX MXP-2300D.1
This amp will hold 1/2 ohm
Its a special order amp.
I ran 4 12's with it at 1 ohm.
500 Shipped on this one. It retails for 1100.
Heres the specs on it
Competition Power- 2300D.1: 2300Wrms @ ½ ohm
(special order) 2300D.2: 2300Wrms @ 1 ohm
Power: 2300D.1 -1500Wrms@ 1 ohm
2300D.2 -1500Wrms@ 2 ohm
Peak power:2300D.1- 3000W x 1@ 1 ohm
2300D.2- 3000W x 1@ 2 ohm
Frequency Response: (-3dB) 10Hz to 230Hz
Signal to Noise Ratio: -92 dB A weighted
Distortion @ rated output: <0.1% THD+N
Input Sensitivity: 150mV to 4Vrms
Idle Current: 1 amp
Dimensions LxWxH: 12" x 9 ¼" x 2 1/8"
The big one in the middle
sleepingciv
Oct 8, 2012 09:28 AM
ReDemoN
Aug 20, 2007 11:59 AM
DigitalFusion
Sep 27, 2003 12:56 PM
