A/C noise
Heres my problem. When i start the car and mind you its still cold now hasn't warmed up yet. I turn on the a/c and i get this really loud noise sounds like its from a belt. What belt and how can i make the noise go away. Or how can i fgure out what belt.
PLease help before i take the peice of ___ and smash it into a wall.
91 accord ex a.t. about 90somethin thousnad miles
Not sure if its the same noise, but my old car (95 chevy cavalier
) used to squeal when the a/c was on, especially when it was raining or just humid outside. If you can't replace the belt, what I used to do was spray some lubricant on the belt <U>every</U> morning so that I wouldn't hear it. You could also use this to figure out what belt is making the noise.
[Modified by p0pe, 7:00 AM 6/11/2002]
) used to squeal when the a/c was on, especially when it was raining or just humid outside. If you can't replace the belt, what I used to do was spray some lubricant on the belt <U>every</U> morning so that I wouldn't hear it. You could also use this to figure out what belt is making the noise.[Modified by p0pe, 7:00 AM 6/11/2002]
Check the tension on the a/c belt. The a/c compressor is on the bottom towards the front. If it's loose you need to make the adjustment on the alternator since the a/c compressor is mounted solidly.
