Need Help anyone that has a 89-91 crx or 92-95 Honda Civic with a 1.6
Ok heres the Deal I have a 89 Honda CRX with a 1.6 in it but someone has mixed this car up so so bad. The Timing Belt went out of it and the one for a 89 1.6 was to small and so i had to get a 90'd timing belt now i had to recently replace a Sensor on the motor and come to find out it the sensor that a 90 calls for is to small for it and it was actually a sensor from a 93 1.6. so we got to looking and the wiring harness is all chopped and peaced can some that has a stock motor for a 89 1.6 send me a pic , also I need a pic of a 90 1.6 and a 92-95 1.6. Please Help me out!!! you can leave it on here or message me at clinardjl@yahoo.com, I will check this site everynight and i am always checking my E~mail.
J. Clinard
J. Clinard
man...sorry to tell ya....but SEARCH!!!! the button is right at the top....someone should make it huge and blink all sorts of bright colors.....
first is your car si or dx or hf. sounds like it could have been dx and someone could have tried the mpfi conversion. then at that point it could be different types of 1.6 engines. could be d16a(jdm), d16a3(88-91 ex) d16a6 (88-91 si) d16y7. could be anything. just look at the stamp on the front of the block itll say. the 92-95 would be vtec d16z6. its too many.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poizin »</TD></TR><TR><TD CLASS="quote">the only numbers on the front of the motor and they are: PM3-17 and 7502817</TD></TR></TABLE>
There should be a block code above the "7502817". What is it? (I assume you saw this near where the engine and trans meet on the front of the block?)
