head gasket spacer
Old Jul 31, 2007 | 11:43 AM
ddenson's Avatar
Default head gasket spacer
Does anyone know of someone who sells headgasket spacers to lower the compression? I bought a b18c motor with raised compression pistons in it and type R camshafts and on the first crank, the pistons bent every one of my exhaust valves, so I think I am going to put my stock GSR cams back in, but I would still like to lower my compression a little. Any help would be appreciated.
Old Jul 31, 2007 | 11:55 AM
climb_on's Avatar
Default Re: head gasket spacer (ddenson)
why not just get better valves....
why do you want to loose that compression...
Old Jul 31, 2007 | 12:00 PM
ddenson's Avatar
It had brand new valves in it.
Old Jul 31, 2007 | 12:02 PM
spets's Avatar
are you sure the timing is set right and everything? could be a mistake in the build or parts are not lining up.
Old Jul 31, 2007 | 12:06 PM
ddenson's Avatar
When I bought the motor, the head was completely redone, so I dont know all the specifics on it. I lined all the up marks up before cranking, I think that the lobes on the cam are too big and pushed the valves into the piston, bending all the exhaust valves. I think I am just going to put my stock GSR head back on the motor and sell the other head.
airmaxbri
Nov 7, 2009 10:59 AM
AlwayzSpoolin
Jan 17, 2007 05:53 PM
Nolan
Sep 15, 2004 05:29 AM
0evilEMPIRE0
Oct 2, 2003 07:43 PM
