cant figure ouut how to install my speaker :/
I have a 94 prelude VTEC and I have a speaker between my backseats and can not figure out how to get the seat part off, can someone help me out please.
on the bottom of each seat there are two pull tabs. You pull those forward, and the seat pops loose. It usually helps to press down on the seat to reduce the force on the seat latch.
Then after that you sorta lift and slide the seat forward. Everything else is pretty straight forward. Remove the seat backs, then I think you need to pop off the trunk hatch trim, and pull some odd press connectors, and such.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">then I think you need to pop off the trunk hatch trim</TD></TR></TABLE>
^^Don't know anything about that and I've removed mine from my Si Model many times and removed the Complete Assembly from a VTEC also.
But otherwise that's pretty much it..
It shouldn't be to hard/confusing.. I've never looked at the manual to figure out how to remove the interior.. It's all pretty self explanatory... Although the dash might be a different story..
im sorry but i dont know exactly wat your talking about, well i think i do but is there any way you can show a picture or something?
Just stick your hand under the front of the seat and you will feel two different clips.
These clips have a handle on each one that will need to be slid/pulled forward. Its usually easier to push down on the front of the seat to release some pressure. Other then that I'm going to tell you to search for a pic. I figured it out w/o a pic, so I can't really say where you could find one. Maybe look in the pic thread for someone's interior that has been gutted, and then look at the front area where the seat should be. There should be two connectors for each side.
Sorry I can't help you further then that.
Man, I'm way to nice... Search for them, found 'em, copied 'em, and Hosted them on my site..
Here's the Manual Pictures on how to Remove the Rear Seats and how to Remove the Woofer Assembly. If these don't help, then you're stuck...
http://mlbz521.scorchgaming.co...1.JPG
http://mlbz521.scorchgaming.co...2.JPG
Good Luck
Good Luck
well thnks alot i ended up figuring it out. i thought i was probably wrong befor so i wanted to make sure i was right. it was just really stuck on there. well thnks again.
soberstan
12
Oct 22, 2004 12:01 PM
