lug nuts for oem wheels?
Old Jul 31, 2007 | 08:37 AM
accorkie's Avatar
Default lug nuts for oem wheels?
heard somewhere some aftermarket lug nuts shouldn't be used on oem wheels. Looking for suggestions on which lug nuts can be used on oem wheels without causing damage? or can you use any lug nuts? Need something effective but not too costly. thx
Old Jul 31, 2007 | 09:23 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug nuts for oem wheels? (accorkie)
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING.
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">What lug nuts do I need?
The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. Aftermarket wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure.
The threading spec for our lugs is 12x1.5</TD></TR></TABLE>
You can buy lug nuts with a ball-shaped seating area at your local Honda/Acura dealer. You can also get them at some auto parts stores; I know Autozone has them for just over a buck apiece. Just make sure you get the ones with the ball-shaped seat.
showcivic2001
Oct 17, 2008 04:14 PM
PowerPig
Aug 11, 2008 05:05 PM
G'Funk
May 6, 2007 09:17 AM
99fbpem1
Aug 28, 2006 11:41 AM
99_dc2
Feb 21, 2006 01:05 PM
