Please help..Radiator fans only run with AC on..
Old Jul 30, 2007 | 11:35 PM
b18bfreak's Avatar
Default Please help..Radiator fans only run with AC on..
Both fans work find with AC on. But do not come on at all with AC off. Car then starts to overheat. Any ideas?
Old Jul 31, 2007 | 04:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Probably a problem w/ the water temp sensor near the thermostat housing.
Old Jul 31, 2007 | 04:56 PM
b18bfreak's Avatar
Default Re: (PatrickGSR94)
I need a little more than "probably". Anyone else experience this?
Old Jul 31, 2007 | 05:04 PM
Ldc4S's Avatar
Default Re: (b18bfreak)
it might be the water temp sensor because its not telling the fan to come on to cool your engine at that certain temp
Old Jul 31, 2007 | 05:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bfreak &raquo;</TD></TR><TR><TD CLASS="quote">I need a little more than "probably". Anyone else experience this? </TD></TR></TABLE>
lol you're asking for an online answer with no hands on diagnostics...a "PROBABLY" is the only thing you should trust. If someone says "definitely", you should question it.
Check the relays and the water temp sensor/sender. Sounds more like a relay problem to me, though. Also, are your grounds all present?
Old Jul 31, 2007 | 05:36 PM
myfirstdc2's Avatar
Default Re: Please help..Radiator fans only run with AC on.. (b18bfreak)
test your ect switch.use a dvom. also check the relay from underhood fuse box. if u can jump the fan relay there then u know u have continuity from wire to fuse box to fan. also u can jump the ect switch as well to see if u have a open in the wires. from there u should be able to narrow down your problem. very simple if u test in the correct procedure.
Old Jul 31, 2007 | 05:46 PM
DookieHowser's Avatar
x2
it just happened to me
civicguy167
Dec 31, 2012 07:16 AM
91DApwr
Nov 3, 2006 08:50 PM
baonest
Sep 6, 2005 07:59 AM
wickedxbo1
Sep 12, 2001 08:49 PM
