5th gen bad auto tranny
Old Jul 30, 2007 | 08:54 PM
moridinx's Avatar
Default 5th gen bad auto tranny
I've got a 5th Gen prelude with a slipping tranny, and a rebuild is out of the question since it is so expensive.
I was wondering what my options are if I'm on a budget?
I know a lot of people recommend doing a manual swap, but the costs seem to add up for that.
I can get another automatic tranny for $500, is that my best bet?
It seems like H22A (93-96, 4th gen) trannys are a lot cheaper, but I'm not sure it would work since the 5th gen autos have tiptronics.
Any help would be greatly appreciated.
Thanks!
Old Jul 30, 2007 | 09:10 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: 5th gen bad auto tranny (moridinx)
5spd swap
Old Jul 30, 2007 | 09:39 PM
MLBZ521's Avatar
Yea, a 5spd swap's gonna cost quite a bit also..
I dunno if I'd pay $500 for an Auto tranny, you should be able to get one for less.. Most people just try and give them away as they're not needed.. Maybe you can find someone with a JDM Swap that has an Auto tranny and get it from them.. That would be your best bet in my opinion.
Old Jul 31, 2007 | 07:25 AM
Mudlocked's Avatar
Do the 5spd swap. Everything would be less than 1500, and that is if you got a shop to do it. Including clutch, flywheel, tranny, axles, linkages, shifter assembly, and a little wiring to still be able to use your auto ecu.
Old Jul 31, 2007 | 07:30 AM
preludestud11's Avatar
Default Re: 5th gen bad auto tranny (Mudlocked)
5 speed swap! you can reuse your auto tranny ecu, and you wont have to worry about the auto tranny pooping again, because it will.
Old Jul 31, 2007 | 10:37 AM
moridinx's Avatar
Thanks for the suggestions. I've been told an Accord tranny would work; does anyone know what year tranny? Would I need to swap anything else out?
Old Jul 31, 2007 | 08:13 PM
MLBZ521's Avatar
Default Re: (moridinx)
Auto or 5spd? I know the 5spd's will work. Haven't actually heard of someone using an Accord Auto in the Prelude, but I don't see why it wouldn't work if the 5spd is the same.
Old Jul 31, 2007 | 08:39 PM
H22Honda98's Avatar
i did the auto-5spd swap in my 98. best move i ever made. costed less than $1200 in the end. dont even bother with an auto. once you do it you wont ever look back.
tpot90
Feb 24, 2008 07:35 PM
preludeez
Feb 3, 2005 10:54 AM
rkonfire
Sep 14, 2004 07:39 AM
