ls/vtec safe rev limiter?
Old Jul 30, 2007 | 08:06 PM
Lordofdark176's Avatar
Default ls/vtec safe rev limiter?
im getting an ls vtec motor put in my car this week and i want to know what i can safely rev to so i can set the rev limiter on hondata. from what i know: its a b18b1 block with a b16 head, type-r cams and aftermarket cam gears. tranny has a quaife lsd in it also, not that that would have anything to do with it i dont think. So what is a safe rev limiter to use? i was thinking dont take it over 7k normally but if im in it to win, so to speak, 7500 would be the absolute limit i would take it to. i just don't want to blow it up. help?
Old Jul 30, 2007 | 08:53 PM
civicman69x's Avatar
Default Re: ls/vtec safe rev limiter? (Lordofdark176)
If the motor is done right you could go up to 8,500 but dont hold it ther to long the block isnt made for high RPM.
Old Jul 30, 2007 | 08:56 PM
.PLUMMM's Avatar
it depends a lot on how i was built and the tune. you should at least be able to take to to 8,000 safely but ive seen ls/vtec setups rev out to 8,500 with just ARP head studs. just make sure it was built right and talk to whoevers tuning it
Old Jul 30, 2007 | 08:59 PM
red02s2k's Avatar
bro i am boosting on my b20vtec which are the exact same expect the 84mm bore and i take it to 82 or 8500 all the time.
Old Jul 30, 2007 | 09:19 PM
from what i know, its a stock b18b1 bottom end with a stock b16 head other than type-r cams and cam gears. if i took it to 7500 would it already be in vtec for the next gear? thats the main reason im asking because i know in my old d16 motor with a 7200 rev limiter, it wouldnt shift into vtec. would 7500 get it into vtec for the next gear?
Old Jul 30, 2007 | 09:28 PM
smileycvc's Avatar
Default Re: (red02s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red02s2k &raquo;</TD></TR><TR><TD CLASS="quote">bro i am boosting on my b20vtec which are the exact same expect the 84mm bore and i take it to 82 or 8500 all the time.</TD></TR></TABLE>
you take a stock block b20 boosted and rev it that high??
Old Jul 30, 2007 | 09:32 PM
EGhatch87's Avatar
i take my ls/vtec to 8000rpm with arp rod bolts never had any problems
Old Jul 31, 2007 | 07:42 PM
red02s2k's Avatar
i have hit 9200 a couple of times in first gear
Old Jul 31, 2007 | 07:52 PM
Colby71's Avatar
put it on a dino find where peek power is rev 200 rpm's over that. If she goes bild it right.
Old Jul 31, 2007 | 09:50 PM
99_EM_one's Avatar
oh well,the guy who build mine told me that you can go till 7500 but you stop making power at 7200! the ls crank don't rev that high,so im not going over that plus its safer!!
Old Jul 31, 2007 | 11:07 PM
smileycvc's Avatar
Default Re: ls/vtec safe rev limiter? (99_EM_one)
what do you mean the crank doent go that high? I used to rev my b20 out to 9k and it the same crank and bearings as an LS. I just had rods and rod bolts. Also whoever built your motor cant tell you where it stops making power unless they already tuned it on the dyno. Just upgrade to some ARP rod bolts and you can rev the poop out of it if you want.
Old Jul 31, 2007 | 11:26 PM
blake_mp's Avatar
Default Re: ls/vtec safe rev limiter? (smileycvc)
a buddy of mine has a stock LS block and head with cams and has taken it to 8500 just about every dry weekend. lol. has had no problems.
Old Aug 1, 2007 | 04:37 PM
doood's Avatar
been there done that
Default Re: ls/vtec safe rev limiter? (blake_mp)
stock ls bottom end = stock ls rev limit
just because someones friend's brother's gay cousin's roomate has taken their stock lsvtec higher and gotten lucky doesnt mean you will.
Old Aug 1, 2007 | 05:02 PM
smileycvc's Avatar
Default Re: ls/vtec safe rev limiter? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
just because someones friend's brother's gay cousin's roomate has taken their stock lsvtec higher and gotten lucky doesnt mean you will.</TD></TR></TABLE>
lol, but very true.
Old Aug 1, 2007 | 05:04 PM
R Benefits's Avatar
If the block is stock, and you just have head work, I wouldn't take it past the stock LS rev limiter.
Sk8ermane
Feb 17, 2008 09:12 AM
jdmgeezer
Oct 13, 2007 04:00 AM
teamitr
Sep 1, 2007 07:41 AM
sikcivic95
54
Dec 1, 2004 11:48 PM
jdm_integ
Apr 13, 2003 10:19 PM
