I need some OBD2 help folks
Old Jul 30, 2007 | 07:30 PM
baksdafukup's Avatar
Default I need some OBD2 help folks
01 GSR.
what would cause the check engine light to flash at idle and go solid after 3500 rpm? every time i dip below 3500 rpm, the check engine light starts flashing again. and it doesn't give any codes. when i jump the wire, the check engine light just stays solid.
BACKGROUND: i got codes 73 and 74 for misfire. so far since i got codes, i have replaced the fouled plug, #3, swapped plug wires, checked the distributor cap and rotor, and did a valve adjustment.
after the valve adjustment i smelled a lot of gas in the first two minutes. then the engine started idleing smoother for a few minutes and the gas smell went away. then it went back to the same old tricks. running really rough and the check engine light started flashing again.
93 DET
Feb 14, 2012 12:36 PM
yeahyeah1469
Sep 30, 2010 06:18 AM
03djmAccrd
15
Sep 25, 2010 04:33 PM
angryk
Honda Civic (2001 - 2005)
Dec 28, 2007 11:53 AM
PearlH22
Mar 29, 2006 11:18 AM
