weird brake noise
when ever i step on my brake pedal while in motion i get a loud pop noise from my engine bay, my braking isnt affected, its just like a loud snapping popping noise, any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rapid Rex »</TD></TR><TR><TD CLASS="quote">when ever i step on my brake pedal while in motion i get a loud pop noise from my engine bay, my braking isnt affected, its just like a loud snapping popping noise, any ideas?</TD></TR></TABLE>
Any play in the steering wheel when it happens?
Could be a ton of things from bad motor mounts to a loose shock upper mount bolt. Try to be a bit more specific. As WizCo said, do you get any steering wheel shake? Which area of the engine bay specifically? Have you popped the hood/checked around for loose bolts/cracked rubber?
be more specific and we can try to help you better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rapid Rex »</TD></TR><TR><TD CLASS="quote">no play in my steering wheel, if i pull my e brake to stop it doesnt do it, so it must be something in my brake system?</TD></TR></TABLE>
Motor mounts OK? I had this problem on an old Camry and it turned out that the bolt for the front motor mount was snapped.
AnAccordIsForever
May 16, 2016 10:35 AM
GUNNER666
Aug 8, 2004 12:06 PM
