A Few Problems on this Accord
Old Jul 30, 2007 | 03:54 PM
koruptor's Avatar
Default A Few Problems on this Accord
I just picked up a used '96 Honda Accord EX, but it came with a few problems.
1. Horn doesn't work when you press the buttons on the steering wheel. Does a fuse exist for this device?
2. When power lock switch (de)activates a grinding sound comes from inside the driver door. Perhaps the power lock "motor?"
Anybody know how I may remedy these problems? Have anyone had these problems?
Old Jul 30, 2007 | 05:20 PM
hondadude's Avatar
Default Re: A Few Problems on this Accord (koruptor)
The horn buttons are in the ground path of the relay coil circuit
Yes the horns have a fuse. Do your brake lights work? Link for you;
http://members.troublecodes.ne...h.bmp
Those power lock actuators can be removed from the latch [door panel off] then open it up and there is a little plastic tab that breaks loose. I shim up behind the tab with little tiny washers and epoxy glue them in place.
jawsk2
Aug 26, 2022 02:00 PM
kpjuni
May 22, 2013 08:49 PM
culinaryjeremy
Apr 30, 2008 04:12 PM
jth8448
Feb 4, 2008 08:47 AM
H22AJSPEC
Oct 3, 2003 11:29 AM
