***CODE 20*** ECLECTRICAL LOAD DETECTOR HELP!!!!!!!!!!!!!!!
i got this code today after swapping in a motor in my del sol. its a CODE 20 ECLECTRICAL LOAD DETECTOR. i just want to know what causes thise code to happen. im using the same engine harness as i used before in my last motor setup and worked just fine. now its giving me this code. does anyone know? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IOSUA »</TD></TR><TR><TD CLASS="quote">anyone know?????</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IOSUA »</TD></TR><TR><TD CLASS="quote">anyone know?????</TD></TR></TABLE>
There's a short in your harness someplace.
To locate it, start pulling fuses outta the under-dash fuse box. Once you find the one that's blown, get a fuse box diagram (I'll post one in a second) and find out what it controls.
Then you check the harness that that thing controls and that's where the short in your harness is.
Usually it's fuse 15 due to the secondary O2 sensor or the VSS sensor.
It grounds out to the chassis.
Find out which fuse is blown.
