Rear integra brake swap.. Now passenger side has massive positive camber.
Old Jul 30, 2007 | 11:06 AM
Slammd Sol's Avatar
Default Rear integra brake swap.. Now passenger side has massive positive camber.
Car is a '95 civic CX. Swapped on Integra rear disc brakes (the whole assembly) and after completing the swap, the rear passenger side has massive positive camber (about 5-6 degrees). I also swapped on Megan racing LCAs at the same time. I inspected everything and all the bolts are tight and nothing looks bent. Any ideas what the problem could be? The driver side is perfectly fine..
Old Jul 30, 2007 | 11:34 AM
justinCO's Avatar
Default Re: Rear integra brake swap.. Now passenger side has massive positive camber. (Slammd Sol)
Get an alignment?
Old Jul 30, 2007 | 11:41 AM
trrbl1bmx's Avatar
definatley an alignment....
Old Jul 30, 2007 | 11:58 AM
Slammd Sol's Avatar
Will an alignment be able to fix 5+ degrees of positive camber?
Old Jul 30, 2007 | 12:07 PM
justinCO's Avatar
Default Re: (Slammd Sol)
If it's that bad something probably got assembled wrong. Triple check everything or have someone else look at it.
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
stevanrk
Suspension & Brakes
Sep 21, 2008 02:17 PM
Wazup
Suspension & Brakes
Apr 29, 2005 08:10 PM
dng
May 25, 2004 07:29 AM
JrJ93vx
Apr 30, 2003 10:56 AM
