Testing Waters: 98+ integra headlight with tsx retrofit.
Old Jul 30, 2007 | 10:00 AM
b20acura's Avatar
Default Testing Waters: 98+ integra headlight with tsx retrofit.
I just want to know what you guys would pay for this.
It's a tsx clear lens retrofit, and black house headlights.
Old Jul 30, 2007 | 01:42 PM
JdmTypeRdc2's Avatar
well some nice pics of the cutoff and craftsmanship of the retro would be nice, but id say you can probably get anywhere from 500-800 for it.
it all depends if theyre oem headlights or not. if theyre aftermarket black housing halo projectors, they would probably go for less.
Old Jul 30, 2007 | 05:59 PM
b20acura's Avatar
Default Re: (JdmTypeRdc2)
will get pics of cut off and everything later. its oem, just black housed it to reduce glare.
Old Jul 30, 2007 | 07:02 PM
kptrulee's Avatar
Default Re: (b20acura)
i've seen prices from $350-600
gl, and like jdmtyperdc2 said, its all about the pics
Old Jul 30, 2007 | 07:08 PM
b20acura's Avatar
Default Re: (kptrulee)
here are some shitty pics
Old Aug 1, 2007 | 11:30 PM
b20acura's Avatar
Default Re: Testing Waters: 98+ integra headlight with tsx retrofit. (b20acura)
here are some more pics
Old Aug 2, 2007 | 02:59 PM
very nice pics...the cutoff is a little misaligned but that can easily be fixed...its aimed a little high.
besides that, they look very good.
i would have bought them if i didnt send mine out 2 days ago (literally) to get them retrod by my friends down at customlightz...
if you would have posted this a week ago, i would have bought them...lol
anyway, good luck if you decide to sell them...if i were you, i wouldnt, cuz that light output is awesome...
why are u thinking about selling them? upgrading to a jdm front with hid???? that would be sick
Old Aug 2, 2007 | 03:22 PM
b20acura's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmTypeRdc2 &raquo;</TD></TR><TR><TD CLASS="quote">very nice pics...the cutoff is a little misaligned but that can easily be fixed...its aimed a little high.
why are u thinking about selling them? upgrading to a jdm front with hid???? that would be sick</TD></TR></TABLE>
haha yeah gota fix the aim.
i shouldve put them up a week ago, was contemplating it.
want to sell them so i can get after market ones with the clear lens. the stock ones got the lines on it that i dont like. nothing wrong with it, just think itll look cleaner with clear lens.
Old Aug 3, 2007 | 06:17 AM
theres a very easy solution it that im actually doing right now...
im wetsanding the lines off the inside...mines came out wonderful...clearer than the clear lenses...
plus oem housing is always better than the cheap aftermarket ones to retro...
if youre worried about the lenses, just wetsand them and clear the lines out yourself...its super easy and it looks beautiful...
Old Aug 3, 2007 | 06:20 AM
ill post some pics of them when im finishing them up...im actually doing this for other people, so im a little busy but ill post pics of mine when theyre completely done...with the retro and everything.
oem&gt; aftermarket....the plastic housing is of much better quality and the adjustments are way better on an oem headlight.
something to think about ....
Old Aug 3, 2007 | 07:24 AM
b20acura's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmTypeRdc2 &raquo;</TD></TR><TR><TD CLASS="quote">theres a very easy solution it that im actually doing right now...
i was thinking about doing this, but didnt know how it would turn out
Old Aug 3, 2007 | 02:57 PM
it turns out really good and its easy to do...just use an electric die grinder, set to soft, and use a 1200 grit sheet to start...once the lines are removed, you can then start using the 1500, 1800, 2000 grit, respectively or even more but this time sand it down by hand to make it smoother....once thats done, and everything is even and clear, just use 3m rubbing compound, followed by meguiars scratch x or any other scratch remover would work...
i also thought it was going to be really hard to do, and sanding by hand, especially to take out those 3 thick lines, is very hard.
but by using the electric grinder to take the 3 lines out, and then sanding the rest by hand to make it smooth, is a piece of cake...
once im done, im most likely gonna put up a diy on this, so that more people could see the process as it happens...
hope this helps..
Old Aug 3, 2007 | 03:56 PM
b20acura's Avatar
expletive. wished i knew this before i glued everything back together. i might try this.
Old Jan 14, 2008 | 04:18 PM
ek4 coupe's Avatar
want to sell your lights?
mr_willy_g
May 13, 2007 05:10 PM
handa
Apr 12, 2005 02:02 PM
Chase
15
Feb 2, 2005 10:30 PM
23psi4age
28
Mar 15, 2003 05:35 AM
TurboDC4
Jun 30, 2002 07:52 PM
