jdm b16 lsd trans??
I have a quick question about axles used for this trans. I have a stock gsr motor and a b16 lsd cable trans thats going into a 88 civic hatch. What axles are used on either side? I have just heard rumors of needing to buy the crx jdm axles etc and just wanted to clear it up before I bought anything. I am using the suspension off of a 96 gsr in the if that would make any difference? I had da suspension on their before but thought since the gsr has a little bit bigger brake set up in the front why not. Thanks for all the help!
well, figure out what year 1/2 shaft youve got...thats the year of axle seals youll need to prevent leaking...im using a 98 1/2 shaft, therefor i use 98 axle seals...it doesnt matter what year axles you use, as long as theyre b series...anywhere from 90-00 will work...ABS or not...ive got ABS gsr axles and they work fine
ps, im using a 91 JDM Y1 LSD B16 tranny
ninty7hatch
30
Jul 19, 2010 01:09 PM
indicajones
Jun 3, 2007 10:37 AM
