[FS/WTT] Integra 22mm Frnt Sway, L.C.A's, H&R Sport Springs, K&N Filter: Legend
$ 35 Pickup *DC2 Integra 22mm Front Swaybar (**needs new endlinks and bracket bolts m 8mm x something.) Comes with Frame brackets and bushings., shipping is extra $10 each Front Integra Lca's (Doesn't have the "wing portion" anymore. i.e. the side piece that has the holes for a swaybar endlink)!!!!!
Here is what i have:
The Swaybar with the (2) ''c'' shaped mounting brackets and the (2) bushings that secure it to the Subframe. (no 8mm bolts for it though)
I do Not have endlinks, the salvage yard gave me the swaybar with bent bolts on them. and the bushings were shot. So ''one'' will need to pickup a set via online discount parts bin etc. or Autozone, Oreilys , advance etc. they run for ~ 35+ each though.. so i would use a hookup at a dealership or order online..
as far as the Lower control arms go, there are normally two major parts.
the first is a One piece unit w/ three bushings/holes to attach to the subframe, the dropfork on the shockbody, and the Knuckle/hub.
the Second is like a "side attachment" which bolts to the Main LCA and looks kinda like a wing. It contains the hole which the Endlink of the swaybar mounts into.
I Do Not have the "wing" portion of the Lca, but the main portion. It has good bushings in it and is beefier than a civic one. (could serve as more durable and possibly more stable in handling considering it is stronger and reinforced. )
I
SPRINGS ARE gone
K & N Air filter Is Gone!
Modified by SpoonSportsJunkie at 2:53 PM 9/19/2007
Modified by SpoonSportsJunkie at 6:57 PM 10/10/2007
Modified by SpoonSportsJunkie at 1:32 PM 10/30/2007
Modified by SpoonSportsJunkie at 5:25 PM 1/29/2008
sup dood? how you been?
what the deal on the lcas? they dont have endlinks? do you have the endlinks for the sway bar? if you have the end links i might pick it up. call me if you have my number still....
autoxsol
Sep 18, 2003 10:14 AM
