major problems/need help for b16a swap
Old Jul 30, 2007 | 08:37 AM
racereaper7's Avatar
Default major problems/need help for b16a swap
i swapped a b16a into a 95 integra ls. i need to know if anyone knows a site that has the engine wiring harness layout for a 95 integra ls. the firing sequence for a b16a both injectors and plugs/distributor. will not turn over all the way. and also the wiring for vtec from the ecu (p30) from the 95 integra wiring harness (reason why i need the engine wiring harness layout) any and all help would be great. thank you very much for any and all help in advance.
Old Jul 30, 2007 | 09:00 AM
Default Re: major problems/need help for b16a swap (racereaper7)
ok i may have found the engine wiring harness info now all i need is info on the b16a second gen engine. im useing the injectors from the ls and in need to know the firing sequence on that and the spark plug/distributor.
****but the main thing know is if anyone has info on wiring the vtec into the integra. i mean useing the ls engine wiring harness and wiring through that and attaching it to the engine and the computer.****
please help is really needed and fast. thanks again for any help.
S3XUN8
Dec 20, 2011 05:49 AM
bigdane0g
Aug 19, 2007 06:19 PM
itrhatchling
Jan 27, 2006 08:43 PM
