1990 civic b16a frequency
Old Jul 29, 2007 | 11:13 PM
fiji_crx's Avatar
Default 1990 civic b16a frequency
would any1 know wat would be the frequency setting for b16a gearbox.as the autogauge 5" Electrical Speed Meter 0-300KM/H (W/Warning-Light)uses only frequency setting would any1 know abt this?
Modified by fiji_crx at 1:18 AM 7/30/2007
Old Jul 30, 2007 | 03:11 PM
fiji_crx's Avatar
Default Re: 1990 civic b16a frequency (fiji_crx)
any1 ?????????
Old Jul 30, 2007 | 05:28 PM
dr_latino999's Avatar
So you are asking about the output signal from an electronic VSS, am I correct?
Old Jul 30, 2007 | 05:43 PM
fiji_crx's Avatar
Default Re: 1990 civic b16a frequency (dr_latino999)
yes when i installed this gauge it just goes upto 20kmh n stops dere , the instucation says to set the frequencey. .it says -100 -50khz. wat frequencey would be for my ef9? also dose the speed signal wire from the gearbox goes to the ecu n comes to gauge cluster, or direct from gearbox to gauge cluster. thanks
Old Jul 30, 2007 | 10:50 PM
fiji_crx's Avatar
Old Jul 31, 2007 | 12:22 AM
Ak_ef9's Avatar
It goes to the ecu then to the cluster. The vss signal is coincidentally the B-16 pin.
gunpointllam
Jul 10, 2016 10:41 PM
949
Sep 7, 2007 04:45 AM
kevinoneill
Mar 11, 2004 10:35 AM
