06 accord engine malfunction light
Old Jul 29, 2007 | 07:51 PM
kleen98accord's Avatar
Default 06 accord engine malfunction light
how do you turn off the engine malfunction light on a 06 accord? TIA
Old Jul 29, 2007 | 08:06 PM
JDM_Acccord's Avatar
Default Re: 06 accord engine malfunction light (kleen98accord)
the check engine light?
Old Jul 29, 2007 | 08:08 PM
Default Re: 06 accord engine malfunction light (JDM_Acccord)
yeah. the engine makes a beep noise too.
Old Jul 29, 2007 | 08:14 PM
there is a beep noise coming from the dashboard cluster? or the actual engine itself? if there is a problem, to reset it isnt going to fix the problem.
Old Jul 29, 2007 | 08:19 PM
the beep is actually coming from the engine bay. see, this is what happened. i tried to install an intake filther onto the factory piping but on the O.E.M. filter it has this sensor. and when i took it off and put in the new filter head, i started up the engine. a few seconds later i noticed the "check engine light" come on. so i dont' think there will be any technical problem since i have reinstalled the O.E.M. filther head. if you can find out how to turn off the "check engine light" it will be great help to me.
Old Jul 29, 2007 | 08:29 PM
if you try disconnecting the battery for a minute or so, should reset it.
Old Jul 29, 2007 | 08:33 PM
alright thanks a lot bro
hiforever3
May 6, 2015 04:37 PM
hiforever3
Lighting
May 6, 2015 12:51 AM
Runningbad45
Jul 17, 2012 09:45 AM
mmabe24
Dec 31, 2011 02:07 PM
hw3679
Mar 31, 2004 05:27 PM
