power steering loop issue 95 ex
i installed my intercooler today and decided to do te loop mod to my power steering. mind you this is all with the motor in the car.
THE PROBLEM
i broke the small hard line on the rear subframe right b4 the flare nut that i was suposed to remove. this is the high pressure line.
MY SOLUTION(MAYBE)
cap off that little hard line since i cant get to the flare nut to remove it. then put an actuall breather(little filter) on the rubber hose that went to the power steering cooler?
what do you guys think??
it feels like i expected now but i need to add some fluid(i think) and then do MY SOLUTION if you guys think its feasable.
thanks!
THE PROBLEM
MY SOLUTION(MAYBE)
thanks!
well i did my solution today but it seems like my rack is full of fluid. should i drain the fluid? how can i do this??
when i took all the power steering **** out i turned the wheels back and forth and nothing came out so i figured it was kinda low. but today i tried putting some in thinking that was my prob but it wouldn't take any more fluid.
i guess drain the rack some?? is there a drain plug for the rack??
any help please guys. thanks
there's no drain plug on the rack that I can think of.
do you have a picture of "your solution"? For some reason I'm having trouble picturing what you are referring to.
'06-V6-MT
Jun 30, 2015 05:47 PM
