h22 hatch swap?
Old Jul 29, 2007 | 03:56 PM
wht92lude's Avatar
Default h22 hatch swap?
hi, i am planning on doing an h22 swap into a hatchback in the very near future and am starting my research, and i have a couple questions. I tried to search but all it kept saying was "search failed try again later".
1. Should i get an eg or an ek hatch, and which would be easier or faster ?
2. What all do i need for the swap, besides the motor?
3. any special tools at all?
Thanx for all your help, and i am mechanically inclined just doing my research, i had a prelude with an h22 and loved it so i figured it very fast in a hatch. thanx again
Old Jul 29, 2007 | 04:04 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: h22 hatch swap? (wht92lude)
h2b faq
https://honda-tech.com/zerothread/1998426
h22 swap info.
https://honda-tech.com/zerothread?id=362984
more 92-00 detailed swap info
https://honda-tech.com/zerothread?id=650329
h22 into civic guide
Thread about regular h22 swap axle breakage
https://honda-tech.com/zerothread?id=434668
h/f compression ratio calculator
http://www.zealautowerks.com/hfseries.html
Myth solved about h22 weight. (it's not an issue, ~22 lbs)
https://honda-tech.com/zerothread?id=684550
Debate on h22 vs b18c5 (ITR0
https://honda-tech.com/zerothread?id=626892
Common H/F series engines explained
http://en.wikipedia.org/wiki/Honda_H_engine
H22 FRM sleeves explained
https://honda-tech.com/zerothread?id=2055437
Old Jul 29, 2007 | 05:30 PM
wht92lude's Avatar
Default Re: h22 hatch swap? (ek forever guy)
thanx, but im not putting the h2b on it....i like the h22 tranny.
Old Jul 29, 2007 | 05:50 PM
Ek Forever y0!
You didn't specify, so I gave it all to you.
Old Jul 29, 2007 | 05:51 PM
sageuvagony's Avatar
wow 2 similar threads side by side..
Old Jul 29, 2007 | 06:00 PM
Ek Forever y0!
Default Re: h22 hatch swap? (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht92lude &raquo;</TD></TR><TR><TD CLASS="quote">
1. As far as I know, the 6th gen civic has a larger engine bay that's easier to work with/in.
2. Look here. https://honda-tech.com/zerothread?id=362984
here https://honda-tech.com/zerothread?id=650329
And here https://honda-tech.com/zerothread?id=650329
Like I told you to.
3. Nothing more than a regular B/F/D swap would need.
Old Jul 30, 2007 | 02:23 PM
wht92lude's Avatar
wow, sageuvagonony did you read the whole post, i tried the search and it didnt work. so no need to be a smart ***.
thanx for all the info i never meant for it to come off as rude.
Old Jul 30, 2007 | 03:23 PM
Ek Forever y0!
it's all good.
ls eg
Feb 13, 2008 01:19 AM
93accordsleeper
Jan 17, 2008 03:51 PM
ge_itr
Dec 18, 2006 06:40 PM
jayzonmyfeet
Mar 16, 2005 05:53 PM
