FS:93 eg gsr turbo hatch<<clean,OHIO
-PICS BELOW-
Engine-
-b18c1 block (ERL)
-b16 head (stock)
-darton sleeves
-ERL girdle
-84mm Cp 9:1 forged pistons (best of the best)
-oliver rods (best of the best)
-ACL rod and main bearings
-ARP head studs
-ARP main bolts
-ARP cap bolts
-84mm Cometic head gasket
-brand new water pump
-Earl's oil return and oil feed lines
-FAL slim fan
-apexi full exhaust
-B16 trans
-Quaiffe LSD
-Exedy 8.5lb flywheel
-Exedy clutch
-energy suspension urethane shifter bushings
-DRAG III turbo kit w/ polished Turbonetics t3/t4 turbo
-BLITZ DD
-GReddy catch can
-RC 750cc injectors
-VENOM hi flow fuel rail
Suspension/Brakes-
-GSR front/rear disk brake conversion
-GSR sway bars front/rear
-GSR upper strut tower bar
-GSR lower front tie bar
-Goodrich SS brake lines
-skunk2 extended wheel studs with skunk2 lug nuts
-14 inch stock Hx wheels
Exterior-
- Newer Championship white paint (inside and out)
-VIS carbon fiber hood
-H.I.D headlights (bright)
-oem eg foglights
-oem front lip
-Honda mudguards
-JDM mirror blockoff plates
-tinted windows (light)
-shaved antenna
Interior-
-H.O.P. audio console
-oem radio blockoff plate
-99 civic SI cd player
- SiR gauge cluster-220km/h
-jdm eg6 climate control
-battery relocated to the rear of hatch
-Wire tuck, main fuse box is beneath pass. airbag cover
-no rear seat
-short shifter
-car is completely dyno tuned on 10 psi. runs great,car put down close to 270 horsepower.Motor is capable of much more boost.
Asking 9,500 obro
VIN: 2HGEH2358PH541712
CLICK LINK BELOW FOR SLIDE SHOW OF PICS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANKS
http://www.slide.com/r/3gpp5D4...ginal
Modified by boosted1993 at 2:05 AM 7/30/2007
Modified by boosted1993 at 2:08 AM 7/30/2007
Engine-
-b18c1 block (ERL)
-b16 head (stock)
-darton sleeves
-ERL girdle
-ARP head studs
-ARP main bolts
-ARP cap bolts
-FAL slim fan
-apexi full exhaust
-B16 trans
-Quaiffe LSD
-Exedy clutch
-BLITZ DD
-GReddy catch can
-RC 750cc injectors
Suspension/Brakes-
Exterior-
-oem eg foglights
-oem front lip
-Honda mudguards
-shaved antenna
Interior-
-no rear seat
-short shifter
Asking 9,500 obro
Robs_B18c
Jan 22, 2009 07:14 AM
Spec...G@rage
Nov 1, 2007 07:56 AM
